Replace Spline to Circle - False size
erhan.lale
erhan.lale
i wrote a VBA, which should replace all spline with circles. I get size of spline with GetBoundingBox, calculate center point and create circle on the same place.
Sub spline2circle()
    Dim pt(2) As Double
    Dim rd As Double
    Dim min As Variant
    Dim max As Variant
    Dim cr As AcadCircle
    Dim curSpline As AcadSpline
    Dim ent As AcadEntity
    Dim key As Variant
    For Each ent In ThisDrawing.ModelSpace
        If TypeOf ent Is AcadSpline Then
            Set curSpline = ent
            curSpline.GetBoundingBox min, max
            pt(0) = min(0) + (max(0) - min(0)) / 2
            pt(1) = min(1) + (max(1) - min(1)) / 2
            pt(2) = 0
            rd = (Abs(((max(1) - min(1)) * 0.5)) + Abs(((max(0) - min(0)) * 0.5))) * 0.5
            Set cr = ThisDrawing.ModelSpace.AddCircle(pt, rd)
        End If
    Next
End Sub
You can see screenshot;
green=spline
white= circle
Circle is bigger than spline and aligned to top-right corner of them. Why?
erhan.lale
GetBoundingBox method works perfect with lines or shapes with corner but it is not precise with curves. See screenshot:
code is:
Sub spline2rect()
    Dim pt(2) As Double
    Dim rd As Double
    Dim min As Variant
    Dim max As Variant
    Dim points(0 To 11) As Double
    Dim plineRect As AcadPolyline
            Set curSpline = ent
            points(0) = min(0): points(1) = min(1): points(2) = 0:
            points(3) = max(0): points(4) = min(1): points(5) = 0:
            points(6) = max(0): points(7) = max(1): points(8) = 0:
            points(9) = min(0): points(10) = max(1): points(11) = 0:
            Set plineRect = ThisDrawing.ModelSpace.AddPolyline(points)
            plineRect.Closed = True
        End If
    Next
End Sub
Is there any other way to coreate circles based on spline?
erhan.lale
I can do it even with CorelDraw with really short code. Why is it not possible with autocad?
Corel-VBA-Example:
Sub replace_shapes_with_ellipses()
Dim sr As ShapeRange
Dim srCreated As New ShapeRange
Dim s As Shape
    For Each s In ActiveSelectionRange
        srCreated.Add ActiveLayer.CreateEllipse(s.LeftX, s.TopY, s.RightX, s.BottomY)
        s.Delete
    Next s
    srCreated.CreateSelection
End Sub
Ed__Jobe
I don't have an answer of how to get around this problem, but perhaps the reason why the bb is off could be due to the splines control points, which are not shown. I suspect that vba isn't able to do this. The .net api has a lot more curve functions available.
Ed
How to post your code.
