Regions - Adding elements
I have a series of lines and arcs that create what I believe to be a closed loop. When I run the following code:
Dim Elem As AcadEntity, regionObj As Variant, oLine As AcadLine, solidObj As Acad3DSolid
For Each Elem In ThisDrawing.ModelSpace
'Find the path of the extrusion
If Elem.Layer = "Path" Then
If Elem.ObjectName <> "AcDbLine" Then
Set oLine = Elem
'Find the elements of the extursion
Else
If Elem.ObjectName = "AcDbArc" Or Elem.ObjectName <> "AcDbLine" Then
regionObj = ThisDrawing.ModelSpace.AddRegion(Elem)
Next
Set solidObj = ThisDrawing.ModelSpace.AddExtrudedSolidAlongPath(regionObj(0), oLine)
ZoomAll
I get the error "Invalid Object Array" on the line where I'm trying to add the elements to the region.
You create an array of objects (lines, arcs, etc) then you use that array as
the argument for the AddRegion method. It's difficult follow exactly what
you're attempting to do, could you please explain it further?
Joe
wrote in message news:5196951@discussion.autodesk.com...
Acad3DSolid
Set oLine = Elem
Else
Next
Set solidObj =
ZoomAll
Try this - make sure path is a polyline
Dim Elem As AcadEntity, i as integer, regionObjs() As AcadEntity, regionObj
As Variant, MyRegion As AcadRegion, oLine As Object, solidObj As Acad3DSolid
i = 0
If Elem.ObjectName <> "AcDbPolyline" Then
Set oLine = Elem
Else
ReDim Preserve (regionObjs,i)
Set regionObjs(i) = Elem
i = i + 1
Next
regionObj = ThisDrawing.ModelSpace.AddRegion(regionObjs)
Set MyRegion = regionObj(0)
Set solidObj =
ThisDrawing.ModelSpace.AddExtrudedSolidAlongPath(MyRegion,oLine)
Acad3DSolid
Set oLine = Elem
Else
Next
Set solidObj =
ZoomAll
That seems to work great.
Jeff
