Regions - Adding elements
06:58 AM
- Mute
- Permalink
- Report
I have a series of lines and arcs that create what I believe to be a closed loop. When I run the following code:
Dim Elem As AcadEntity, regionObj As Variant, oLine As AcadLine, solidObj As Acad3DSolid
For Each Elem In ThisDrawing.ModelSpace
'Find the path of the extrusion
If Elem.Layer = "Path" Then
If Elem.ObjectName <> "AcDbLine" Then
Set oLine = Elem
End If
'Find the elements of the extursion
Else
If Elem.ObjectName = "AcDbArc" Or Elem.ObjectName <> "AcDbLine" Then
regionObj = ThisDrawing.ModelSpace.AddRegion(Elem)
End If
End If
Next
Set solidObj = ThisDrawing.ModelSpace.AddExtrudedSolidAlongPath(regionObj(0), oLine)
ZoomAll
I get the error "Invalid Object Array" on the line where I'm trying to add the elements to the region.
Set oLine = Elem
End If
Else
End If
End If
Next
ZoomAll
