How to plot a current drawing to printer
I wish to print drawings in batch with VBA procedure.
I made a procedure which loads the drawings one by one following of the criteria set in a userform.
My problem is : I do not able to manage and to find the instructions and the surely essential parameter setting of the variables and functions.
Currently with the procedure below, I plot a white page with each drawing whereas the drawing is posted correctly in the tab "object" of AutoCAD windows.
Anybody could help me?
I lock for a while on this subject without result.
I use the following instruction
ThisDrawing.Plot.PlotToDevice "Canon MP750 Series Printer.pc3"
Many thanks for your help.
The one line looks fine... Can you post more of the surrounding code? Also, what exactly is the problem? Is it plotting blank pages?
arcticad
The Attached file is a basic outline of the options you need to successfully print a drawing using VBA. I hope it helps.
Any Problems Post a response here. Thank You.
I borrowed the disclaimer from DotSoft But the code is from me.
Thank You.
(defun botsbuildbots() (botsbuildbots))
