Reed from and write to TXT FILE
Message 1 of 10
HI,
I am using VBA editor inside AutoCAD to write my program.
in my program there are variables a1,a2,...a10. and when I run the program I need the program to reed the variables value from TXT file , Also I need to save the program result at text file , please tell me how can I reed and write from and to TXT file. looking for your help
thank you alot
Replies (9)
Message 2 of 10
1. Start Acad;
2. Get into VBA Editor;
3. Press "F1" key;
4. Select "Index" tab and enter "Open";
5. Double-click "Open Statement".
You get detailed explanation on how to open a file for reading/writing and
examples.
wrote in message news:4872659@discussion.autodesk.com...
HI,
thank you alot
Message 3 of 10
Try these samples,
Public Sub WriteFile()
Open "C:\Testfile.txt" For Output As #1 'Open file for output
Write #1, "Hello World", 234 'Write comma-delimited data or
Close #1 'Close file
End Sub
Public Sub ReadFile()
Dim MyString, MyNumber
Open "C:\Testfile.txt" For Input As #1 'Open file for input
Do While Not EOF(1) 'Loop until end of file
Input #1, MyString, MyNumber 'Read data into two variables
a1,a2
Debug.Print MyString, MyNumber 'Print data to the Immediate window
Loop
End Sub
John Coon
"Norman Yuan" wrote in message
news:4872637@discussion.autodesk.com...
1. Start Acad;
3. Press "F1" key;
examples.
HI,
thank you alot
Message 4 of 10
Is there a reason you'd suggest this over the FileSystemObject of WSH?
(Using FSO seems MUCH easier and logical, though I'm not as versed as many
in here.)
1. Start Acad;
3. Press "F1" key;
examples.
HI,
thank you alot
Message 5 of 10
I second the FileSystemObject approach. Go into help and do a search for
"TextStream" and there should be an example for reading/writing to text
files there.
-Chris
1. Start Acad;
3. Press "F1" key;
examples.
HI,
thank you alot
Message 6 of 10
Scripting.FileSystem object is not recommended to be used in VB/VBA program.
There are lots of talks in various VB related NGs that are against using
FileSystem object in VB/VBA program. It is designed for Windows scripting
specifically, and many system administrators even choose to disable Win.
script. With VB/VBA intrinsic file function, there is nothing you cannot do
wihle with FileSystem object you can. Most experienced VB programmers would
definitely avoid to use Scripting.FileSystem object in their VB/VBA program
whenever they can.
"Chris Shoemaker" wrote in message
news:4873461@discussion.autodesk.com...
files there.
-Chris
1. Start Acad;
3. Press "F1" key;
examples.
HI,
thank you alot
Message 7 of 10
Hmmmm.....
>Most experienced VB programmers would definitely avoid to use
>VB/VBA program whenever they can.
Message 8 of 10
So, so true. Remember when the new security model hit those of us trying to do Outlook Web Access and scripting?
Message 9 of 10
Nothing you can't do perhaps, but often at the expense of being 10X more
complex then FSO for anything more advanced. Your point however about ease
of use vs risk for just reading and writing to a text file though is a good
one.
-Chris
news:4873525@discussion.autodesk.com...
whenever they can.
files there.
-Chris
1. Start Acad;
3. Press "F1" key;
examples.
HI,
thank you alot
Message 10 of 10
Thanks for the info, Norman. My thought process was more along the lines of
"if you're using Acad, it's on Windows".
....enlightenment is always a good thing. 😉
whenever they can.
