Dimscale of unopened file?
Is it possible to get variable (or any other information) from an unopened file through VBA? I'm looking to automate the insertion of 20 or so files as xrefs. The scale of the insertions would be 1/dimscale of each of the drawings. Can I find out any information about the drawing without opening it?
The format "dimsc= ThisDrawing.GetVariable("DIMSCALE")" works for an opened, active, drawing. I have the path and file name of the 20 files. Can I do this?
If not, is it possible to turn off screen updating, so the user doesn't see 20 files open and close?
Thanks in advance,
Aaron
If you know the name of the Dimstyle that should be the Style with the
drawing's scale, you could setup a dummy style in the open drawing and use
ObjectDbx/Copyfrom to copy that style to the current drawing's dummy style
and extract the dimscale from it. The actual time it would take to do this
is minmal compared to actaully opening a drawing in the editor.
I'm unaware of any method to use Getvar on unopened drawings.
Jeff
wrote in message news:4872708@discussion.autodesk.com...
it?
this?
Thanks in advance,
Aaron
