"Unlock" DVB file...??
Does anyone know how to "unlock" a DVB file so as to edit it? I've already got VBAKEY, but unfortunately, it doesn't work on all files. Anyone have any suggestions?
You could always contact the author. If that's not an option, you'll have to
start over.
http://www.acadx.com
Good judgement comes from experience.
Experience comes from bad judgement.
"BigCountry" wrote in message
news:f0907bd.-1@WebX.maYIadrTaRb...
suggestions?
VBAKEY should work i've used it & worked ok
it's a dos based program. You need to run from either a
ms dos prompt or select 'RUN' of the windows start button menu.
use: c:\path\vbakey filename.dvb
Just so you know, advising others on how to crack code that most likely
isn't theirs is in incredibly poor taste given the current forum.
Cracking may be a good topic for a warez group but around here, it's just
plain theft.
"trev" wrote in message
news:f0907bd.1@WebX.maYIadrTaRb...
Apologies to all.
just passing on what I learnt in here on a post dated
3/21/2001.
