Path from Xref
Path from Xref
Path from Xref
Does anyone know how to get the path from an Xref? There doesn't seem to be an easy way to do this.
Marc
The ExternalReference object has a Path property. It is a pity that you
cannot get the info from the Blocks collection...
R. Robert Bell, MCSE
http://www.acadx.com
"mrhan" wrote in message
news:f090890.-1@WebX.maYIadrTaRb...
| Thanks,
| Marc
Thanks for the info, but do you know how to link a AcadExternalReference
object to all the blocks and get the path? Can you loop thru the xrefs like
you can blocks? I have been able to look at all the blocks and find out if
they are xrefs (.isxref), but can't seem to figure out the object hierarchy
and how block objects and external reference objects are related. The help
files are pretty useless.
Thanks-Marc
R. Robert Bell wrote in message
news:E3C170259C9169CD90E977B077F515EB@in.WebX.maYIadrTaRb...
> | Thanks,
> | Marc
Use the name property of the Block object to create a filtered selection
set. The objects contained in the selection set can be iterated as either
AcadBlockRefereces or AcadExternalReferences.
Good judgement comes from experience.
Experience comes from bad judgement.
"Marc Rhan" wrote in message
news:E98A599CFA12C4D5BEF1F4633E23E935@in.WebX.maYIadrTaRb...
like
if
hierarchy
help
> Thanks-Marc
Marc,
I believe this is what you're looking for?
Joe
Option Explicit
'DXF Group Code Constants
Public Const ENTITY = 0 'an entity
Public Sub XRefPath()
Dim objSS As AcadSelectionSet
Dim intFilterCode(0) As Integer
Dim strFilterValue(0) As String
Dim BlockRef As AcadBlockReference
Dim Index As Long
Set objSS = ThisDrawing.SelectionSets.Add("Inserts")
CreateSelectionSet objSS, ENTITY, "INSERT"
'MsgBox "Number of entities selected: " & objSS.Count
For Index = 0 To objSS.Count - 1
Set BlockRef = objSS(Index)
Debug.Print BlockRef.Path
Next Index
objSS.Delete
End Sub
Public Function CreateSelectionSet(SelectionSet As AcadSelectionSet, _
FilterCode As Integer, _
FilterValue As String) As Boolean
Dim varFilterValue(0) As Variant
'assume success
CreateSelectionSet = True
intFilterCode(0) = FilterCode
varFilterValue(0) = FilterValue
SelectionSet.Select acSelectionSetAll, , , intFilterCode, varFilterValue
'SelectionSet.SelectOnScreen intFilterCode, varFilterValue
If Not SelectionSet.Count Then
CreateSelectionSet = False
End Function
like
if
hierarchy
help
> Thanks-Marc
to
> > | Thanks,
> > | Marc
