Question on error number (from Ed Jobe cls)
Message 1 of 9
from a post by Ed Jobe, that tirelessly generous vb genius lurking around
here at times, I'm trying to understand a couple lines...
Case Is = vbObjectError + 1001, 70 '70 = file access permission denied
I don't under stand this syntax vbObjectError + 1001, 70
the help for the + operator doesn't have any thing about a following comma
and extra argument so I don't quite know what that's doing
any way on my machine, the error when a drawing is already open
-2147467259
and vbObjectError = -2147221504
so I would think I should be using a line like":
Case Is = vbObjectError - 245755
which is very different, can anyone shed some light on this?
also why is it better to use the vbObjectError constant instead of using the
number directly - I would assume its so if vb rewrites it's constants in the
next version but keeps the offsets the same then the old code still
runs...is that the idea? or is it something else???
question 2: (greedy ain't i?)
another error line is:
Set dbxdoc = AcadApplication.GetInterfaceObject("ObjectDBX.AxDbDocument")
If strExt = "dwt" Then
Err.Raise vbObjectError + 1001
in "vbObjectError + 1001" is the 1001 arbitrary or based on a list of codes
somewhere?
thanks in advance
Mark
Replies (8)
Message 2 of 9
> comma and extra argument so I don't quite know what that's doing
The comma belongs to the Case label, not the addition operator.
> using the number directly - I would assume its so if vb rewrites it's
> constants in the next version but keeps the offsets the same then the
> old code still runs...is that the idea?
Yes.
> codes somewhere?
What you're seeing is an application-defined error. vbObjectError + 1001
will indicate something different in someone else's application.
There are 10 kinds of people. Those who understand binary and those who
don't.
http://code.acadx.com
(Pull the pin to reply)
Message 3 of 9
thanks Frank,
I finally figured most of that out after rereading help some more. Should
have spent more time on that before posting, but the actual returned number
still mystifies me.
Select Case Err.Number
Case Is = -2147221005
Debug.Print "Dbx not registered..."
I get:
Error #:-2147221005 -:- Application-defined or object-defined error
so does that mean that somewhere else in the prog there would have been a
raise statement like
Err.Raise vbObjectError -2147221005
then the next test was for file access denied
now I understand that says if the error was 1001 or 70 ...blah...
but the native value for vbObjectError I guess I don't understand why it's
not 0.
does it vary from machine to machine or is an intrinsic constant in vb
on my machine i get
Sub testerr()
Debug.Print "vbObjectError: " & vbObjectError
Dim ErrorNumber
ErrorNumber = vbObjectError
Debug.Print "Error #:" & ErrorNumber & " -:- " & Error(ErrorNumber)
End sub
with the result:
vbObjectError: -2147221504
Error #:-2147221504 -:- Application-defined or object-defined error
so it's saying the built in constant is application defined...
i think i'm not getting something here.
anyway, thanks for the input, I'll keep studying.
Mark
"Frank Oquendo" wrote in message
news:10616BD329348C49992DB80285B1FEF6@in.WebX.maYIadrTaRb...
> Yes.
Message 4 of 9
> I get:
> been a raise statement like Err.Raise vbObjectError -2147221005???
That's the error number VBA returns when ObjectDBX is not registered. It
wasn't defined by Ed Jobe.
> denied now I understand that says if the error was 1001 or 70
If the error # is vbObjectError + 1001 (-2,147,220,503) or 70, not 1001
or 70.
> on my machine i get
vbObjectError is a constant (-2147221504).
No, the application-defined error code is vbObjectError plus an
arbitrary number. That allows you to establish your own set of error
codes for use in your application. It also makes it easier for end users
to trap specific errors.
don't.
Message 5 of 9
ok, i think i get it now.
Thanks so much!
I wonder why Error(vbObjectError) doesn't return something like "intrinsic
constant"?
instead of "Application-defined or object-defined error"?
I was confusing err.number with vbObjectError constant!
Sub testerr()
On Error Resume Next
If Err Then
Debug.Print "Err num:" & Err.Number & vbCrLf & "Err desc:" & Err.Description
Else
Debug.Print "In an error free state, Err.Number = vbObjectError -
vbObjectError "
Debug.Print Err.Number = vbObjectError - vbObjectError
End sub
Thanks again
Mark
news:20DA2283A27FF24BAD64290FC398C9E9@in.WebX.maYIadrTaRb...
Message 6 of 9
Yeah, it was a long time before I figured out what that error message meant too Mark. It's saying that the program you've written called an external application or an object, and an error was returned from that call that is not recognised natively by VB(A). For example it is possible for a call to something external to return an Error 9 which VB knows is a Subscript Out of Range error (off the top of my head - don't quote me). But if it returns Error 923468326 VB (obviously) has no idea what *that* means, so it gives you the best information it can, ie a call to an application or an object has returned an error that was only defined (has meaning) in that application or object, better known as "Application-defined or object-defined error". One of those things that only makes sense in hindsight I reckon.
In a perfect world the documentation for everything you call/use describes all errors that could be returned so that you can cater for them in your calling application. Watch out for those low-flying pigs!
Regards
Wayne Ivory
IT Analyst Programmer
Wespine Industries Pty Ltd
Message 7 of 9
"wivory" wrote in message
news:f1a40ea.4@WebX.maYIadrTaRb...
I now get that part. I was just thinking since vbObjectError *was* known by
vb(a), since it's an intrinsic constant, that the return code might not the
the "Application-defined or object-defined error". but i've quit trying to
make sense out of it and just accept it.
a bit of amusement from help:
Visual Basic errors (both Visual Basic-defined and user-defined errors) are
in the range 0-65535. The range 0-512 is reserved for system errors; the
range 513-65535 is available for user-defined errors.
...also from help
Unused error numbers in the range 1 - 1000 are reserved for future use by
Visual Basic.
make up your minds guys...
Thanks for the input.
Message 8 of 9
I've been very busy, Mark. I just read this post. Something that wasn't
mentioned about "vbObjectError +1001" is how it makes it convenient to
create custom error #'s. As you mentioned, somewhere else in my code I use
Error.Raise. This error handler comes from a class that handles opening of
dbx doc's and provides error handling for things like when the file is
read-only and opening a dwt instead of just a dwg. There are several places
I raise errors. With this method, you can keep track of simple numbers,
instead of some obtuse number like -2147221504. In the class Declarations, I
have a comment listing the last errror number used. I just started out with
1000. Each time I need a new error number, I just look at the comment and
add one, updating the comment. That way I don't have to search through the
class looking for the last one used.
Ed
"Mark Propst" wrote in message
news:A908BC8BD26065247E550FB5BC6ABF4E@in.WebX.maYIadrTaRb...
call
only
by
the
are
> ...also from help
> Visual Basic.
Message 9 of 9
P.s. Thanks for the compliment. Still in a hurry.
Ed
"Ed Jobe" wrote in message
news:DBAE55729DD90F9E4F01647397E2D6C3@in.WebX.maYIadrTaRb...
places
I
with
> Ed
> call
> only
> by
> the
to
> are
> > ...also from help
by
> > Visual Basic.
