Title Block Editor
Title Block Editor
Message 1 of 20
Title Block Editor
I'm just starting out on a VB.NET project to build a title block
editor/drawing manager.
I ahve the start of some code I am playing with to try to understand how to
edit specific attribute values within a named block. The routine
Change_Attributes should do the trick but I'm confused about how to pass in
the ACAD block reference. I know the block I want to edit the attributes of
is.... oACAD.ActiveDocument.Blocks.Item("TITLEBLOCK_MAIN")
Block: TITLEBLOCK_MAIN
Tag: JOB1
Value: some value
Private Sub btnEditValue_Click(ByVal sender As System.Object, ByVal e As
System.EventArgs) Handles btnEditValue.Click
Change_Attributes(, "JOB1", "I changed this value")
End Sub
Private Sub Change_Attributes(ByVal oBlk As AcadBlockReference, ByVal
sTag As String, ByVal sValue As String)
Dim Attribs As Object
Dim Attrib As AcadAttributeReference
Attribs = oBlk.GetAttributes
For I As Integer = LBound(Attribs) To UBound(Attribs)
Attrib = Attribs(I)
If Attrib.TagString = sTag Then
Attrib.TextString = sValue
Next I
End Sub
Can someone please help out?
TIA
Russ
Replies (19)
Message 2 of 20
Russ,
Make a procedure to get a filtered selection set of the BlockReference(s)
you are interested in (they are called "Insert" for the filter), then pass
the object(s) into your Change_Attributes procedure. There are plenty of
examples of filtered selection sets in this ng, or the help files, or even
on our website.
R. Robert Bell, MCSE
www.AcadX.com
"Russ Green" wrote in message
news:51A86D9CACBF24208E33B33EC9C6529F@in.WebX.maYIadrTaRb...
to
in
of
| Tag: JOB1
| Value: some value
As
| End Sub
| Attrib = Attribs(I)
| End If
| Next I
| End Sub
| TIA
| Russ
Message 3 of 20
Thanks for the reply. Looks like lots of useful code on your site..
So this is the code so far. But the following exception occurs..
Line of code:
ss.Select(AutoCAD.AcSelect.acSelectionSetAll, , , fType, fData)
Exception:
An unhandled exception of type 'System.NullReferenceException' occurred in
_testing application.exe
Additional information: Object reference not set to an instance of an
object.
Code:
Dim CreateSelectionSet As Object
Dim ss As AcadSelectionSet
Dim fType As Object
Dim fData As Object
ss = CreateSelectionSet
BuildFilter(fType, fData, 0, "INSERT", 2, "TITLEBLOCK_MAIN")
If ss.Count > 0 Then
Change_Attributes(ss, "JOB1", "we changed this value")
End Sub
Attrib = Attribs(I)
Next I
End Sub
Public Sub BuildFilter(ByVal typeArray, ByVal dataArray, ByVal
ParamArray gCodes())
Dim fType(), fData() As Object
Dim index As Long, i As Long
index = LBound(gCodes) - 1
For i = LBound(gCodes) To UBound(gCodes) Step 2
index = index + 1
ReDim Preserve fType(index)
ReDim Preserve fData(index)
fType(index) = CInt(gCodes(i))
fData(index) = gCodes(i + 1)
Next
typeArray = fType
dataArray = fData
End Sub
"R. Robert Bell" wrote in message
news:6EB40A017DF2688E550EA2CEF382B57F@in.WebX.maYIadrTaRb...
> Russ,
> on our website.
> www.AcadX.com
> to
> in
> of
> | Tag: JOB1
> | Value: some value
e
> As
> | End Sub
ByVal
> | Attrib = Attribs(I)
> | End If
> | Next I
> | End Sub
> | TIA
> | Russ
Message 4 of 20
Russ,
You're passing a selection set object to a function that expects a block
reference object.
or am I missing something?
value")<------is this right?
> End If
what about something like...
dim i as long
For i = 0 to ss.count - 1
Change_Attributes(ss.item(i), "JOB1", "we changed this
value")
Next
any help?
Mark
news:596E2F17B0D8AF1D33AD049B0AC49111@in.WebX.maYIadrTaRb...
> Line of code:
> Exception:
> object.
> Code:
As
> Dim fType As Object
> Dim fData As Object
> End If
> End Sub
> Attrib = Attribs(I)
> End If
> Next I
> End Sub
> index = index + 1
> Next
> typeArray = fType
> dataArray = fData
> End Sub
> > Russ,
BlockReference(s)
pass
even
> > on our website.
> > www.AcadX.com
how
> > to
pass
> > in
attributes
> > of
> > | Tag: JOB1
> > | Value: some value
ByVal
> e
> > As
> > | End Sub
> ByVal
> > | Attrib = Attribs(I)
> > | End If
> > | Next I
> > | End Sub
> > | TIA
> > | Russ
Message 5 of 20
Mark,
That does make sense but the code still falls over at this line,
Before it even gets to,
Change_Attributes(ss.item(i), "JOB1", "we changed this value")
This is still the same exception
object.
"Mark Propst" wrote in message
news:8B481613075A85CCD0FB320C00DE95BE@in.WebX.maYIadrTaRb...
> Russ,
> reference object.
ByVal
> > End If
> dim i as long
> value")
> Next
> any help?
> Mark
> > Line of code:
> > Exception:
in
> > object.
> > Code:
e
> As
> > Dim fType As Object
> > Dim fData As Object
> > End If
> > End Sub
ByVal
> > Attrib = Attribs(I)
> > End If
> > Next I
> > End Sub
> > index = index + 1
> > Next
> > typeArray = fType
> > dataArray = fData
> > End Sub
> > > Russ,
> BlockReference(s)
> pass
of
> even
> > > on our website.
> > > www.AcadX.com
> how
> > > to
> pass
> > > in
> attributes
> > > of
> > > | Tag: JOB1
> > > | Value: some value
> ByVal
> > e
> > > As
> > > | End Sub
> > ByVal
> > > | Attrib = Attribs(I)
> > > | End If
> > > | Next I
> > > | End Sub
> > > | TIA
> > > | Russ
Message 6 of 20
ss can't be set to an object of any type other than AcadSelectionSet.
Where are you giving CreateSelectionSet a value?
___________________________
Mike Tuersley
AutoCAD Clinic
Rand IMAGINiT Technologies
Message 7 of 20
well I don't know .net .yet so,
this line looks weird to me
(I don't understand the AutoCAD.AcSelect. part of it,)
in vb it would just be
ss.Select acSelectionSetAll, , , fType, fData
so if in .net you're having to identify the constant acSelect with the
preface AutoCAD.AcSelect. for some reason, then why are the args in parens?
if it were vb, since the Select method is not a function returning a value
it would be like:
ss.Select AutoCAD.AcSelect.acSelectionSetAll, , , fType, fData
if it were a function returning a value it would be something like:
(if return was an object)
set something = ss.Select(AutoCAD.AcSelect.acSelectionSetAll, , , fType,
fData)
or
(if return wasn't an object)
something = ss.Select(AutoCAD.AcSelect.acSelectionSetAll, , , fType, fData)
if that's not the problem then i'd look at each object to see which one
isn't set
'System.NullReferenceException' sounds like something that's supposed to be
an object isn't.
so at the point it fails set a watch to ss and AutoCad and see if one of
them is = Nothing for some reason,
the problem would probably, in that event, be somewhere above this line of
code that was supposed to initialize either ss or AutoCad
also in your orig post you were using oAcad , are you changing your variable
names each time?
"I know the block I want to edit the attributes of
is.... oACAD.ActiveDocument.Blocks.Item("TITLEBLOCK_MAIN")"
makes it a little hard to follow exactly whats going on...
you can also put a line before your selection line like:
If ss IsNothing then
Debug.print "warning ss is having a bad day"
elseIf AutoCad(or oAcad or whatever its' really supposed to be) IsNothing
then
Debug.print "warning acad is having a really bad day"
else
....continue with selection attempt
end if
just to help in tracking down the problem
good luck and happy bug hunting! 🙂
Mark
news:4684D00B17682A9A5FFB5D92E64EAB97@in.WebX.maYIadrTaRb...
> Mark,
Message 8 of 20
but it is?
my mistake.
A slight tweak then but still errors in the same place...
Dim fType(1) As Object
Dim fData(1) As Object
Dim oBlock As AcadBlock
'make the empty selection set
ss = CreateSelectionSet()
'build the selection filter
fType(0) = 0 : fData(0) = "INSERT"
fType(1) = 2 : fData(1) = "TITLEBLOCK_MAIN"
'make the selection
'ss.Highlight(True)
Dim i As Long
For i = 0 To ss.Count - 1
Change_Attributes(ss.Item(i), "JOB1", "we changed this
value")
Next
End Sub
"Mike Tuersley" wrote in message
news:MPG.1a3d0868efc7e8ac9897c6@discussion.autodesk.com...
> Mike Tuersley
> AutoCAD Clinic
Message 9 of 20
you're sure it's not...
news:D0807A203AB8E59BF5A8405104AA653A@in.WebX.maYIadrTaRb...
> but it is?
Message 10 of 20
Well .NET completes the parenthesis automatically. It's impossible not to
have them it's the syntax.
Thanks for your responses anyway.
So if you were trying to select a block and edit specific attributes (by tag
name) in vb6 how would you do it differently?
Russ
news:327FE25ED988EEA7EA944755CCFCE27B@in.WebX.maYIadrTaRb...
parens?
> it would be like:
> fData)
> or
fData)
> isn't set
be
> an object isn't.
variable
> names each time?
> then
> else
> end if
> Mark
> > Mark,
Message 11 of 20
sorry, like i said i know nothing about .net
as I mentioned before, in vb the selection would look like:
but obviously that's not the case in .net so hopefully some one whos not
.net challenged will step in
news:13F33A3DA6D85B3818F1E99E0838ACEB@in.WebX.maYIadrTaRb...
tag
> Russ
Message 12 of 20
Yes, show us what CreateSelectionSet is defined as. That is more than
likely where your error is based on the rest of the code you have alredy
shown - it is not part of the AutoCAD API.
Mike Tuersley
AutoCAD Clinic
Message 13 of 20
It's the same in .net as well because this is relating specifically to
the AutoCAD API and not .NET. The issue is the CreateSelectionSet - it
has to return an AcadSelectionSet object. Until we see what/how it is
defined, the thread is pointless - we are speaking one thing and Russ
another. Regardless of the language, by declaring an object of a certain
type, it can only be set to that same type.
Mike Tuersley
AutoCAD Clinic
Message 14 of 20
Russ Green wrote:
> Line of code:
> Exception:
> occurred in _testing application.exe
> object.
Judging from the routine names, you're using toolbox functions from our
site or a knock-off of them. Considering that we have not posted .NET
versions of BuildFilter or CreateSelectionSet (just how *did* you manage
to call it without parens?), I'd say your problem is somewhere in one of
those two routines. Please post them for review.
Some other things to consider:
1) The arguments you're passing for the selection set filter should be
of type Short() and Object(), respectively.
2) BuildFilter is really overkill for filters in .NET. Check this out:
Dim fType As Short() = {0, 2}
Dim fData As Object() = {"INSERT", "TITLEBLOCK_MAIN"}
3) Your selection set object is declared as Object instead of
AcadSelectionSet. While legal (everything derives from Object), it's not
only pointless but a hindrance as you'd have to call all members via
late binding. This is definitely not the way to go.
P.S. I just noticed that you already posted BuildFilter. All I can say
is "Yikes!". While that code is useful in VBA, it's hardly tuned for
.NET. You have to remember that all our VBA stuff is meant for a
language far more crude than VB.NET.
There are 10 kinds of people. Those who understand binary and those who
don't.
http://code.acadx.com
(Pull the pin to reply)
Message 15 of 20
That was a mistake as I declared in by accident.
The CreateSelectionSet funtion looks like this
Public Function CreateSelectionSet(Optional ByVal ssName As String =
"ss") As AcadSelectionSet
Try
ss = oACAD.ActiveDocument.SelectionSets.Item(ssName)
Catch ex As Exception
ss = oACAD.ActiveDocument.SelectionSets.Add(ssName)
ss.Clear()
End Try
End Function
And the main routine looks like this....
as you can see I have already removed BuildFilter() so only leaves
CreateSelectionSet() as a possible problem.
Dim fType(1) As Short
Dim Pt1(0) As Double
Dim Pt2(0) As Double
'make the selection
'ss.Highlight(True)
ss.Select(AcSelect.acSelectionSetAll, Pt1, Pt2, fType, fData)
If ss.Count >= 1 Then
Dim i As Long
Change_Attributes(DirectCast(ss.Item(i),
AcadBlockReference), "JOB1", "we changed this value")
Next
End Sub
And it still falls over here
Russ
"Frank Oquendo" wrote in message
news:D3A3630D7620236721194FB8CD560254@in.WebX.maYIadrTaRb...
> Russ Green wrote:
> > Line of code:
> > Exception:
> > object.
> don't.
Message 16 of 20
>by declaring an object of a certain type, it can only be set to that same
type.
Yeah but the language has to let you declare the correct type in the first
place. It's not .NET its language syntax/structure of VB.NET
Russ
news:MPG.1a3db8629133fa5f9897c8@discussion.autodesk.com...
> Mike Tuersley
> AutoCAD Clinic
Message 17 of 20
> String = "ss") As AcadSelectionSet
> Try
> ss.Clear()
> End Try
> End Function
First, you're not actually returning the selection set; there's no
return statement. Second, move the ss.Clear into the Finally block so it
gets cleared either way.
don't.
Message 18 of 20
So it should be this? You know when you stare at a problem for so long you
overlook the simple errors screeming at you.
Public Function CreateSelectionSet(Optional ByVal ssName As String = "ss")
As AcadSelectionSet
Try
End Try
ss.Clear()
Return ss
End Function
news:C7BC3C20BEB4F00D2569D05FFBE2B2E2@in.WebX.maYIadrTaRb...
> > Try
> > ss.Clear()
> > End Try
> > End Function
> don't.
Message 19 of 20
Real close. See below. I added a Finalyl clause and moved ss.Clear into
it.
> long you overlook the simple errors screeming at you.
I know *exactly* what you mean. 😉
> Try
> Finally
> ss.Clear()
> End Try
> Return ss
> End Function
don't.
Message 20 of 20
OK, Thanks for all your responses. I have the basic functions working now.
So I can now change the value of a named attribute within a named block in
the active drawing.
Next to begin working on the revision block strategy.........
I'll post the basic code for the attribute editor if anyone requests it.
Russ
to
in
of
> Tag: JOB1
> Value: some value
As
> End Sub
> Attrib = Attribs(I)
> End If
> Next I
> End Sub
> TIA
> Russ
