Textbox background color to aci color
I have a text box on a form and I would like users to type in the color
number and have the backgound color of the textbox change to display this
color.
Any ideas?
Russ
Ok, well I kindo got it working excpet that the colours are 1 down the scale
from what they should be. ie 0 = red, 1 = yellow, etc
Function ACIRed(ByRef ACI As Integer) As Integer
Dim Red As Object
Red = New Object() {1, 1, 0, 0, 0, 1, 1, 1, 1, 1, 1, 0.65, 0.65,
0.5, 0.5, 0.3, 0.3, 0.15, 0.15, 1, 1, 0.65, 0.65, 0.5, 0.5, 0.3, 0.3, 0.15,
0.15, 1, 1, 0.65, 0.65, 0.5, 0.5, 0.3, 0.3, 0.15, 0.15, 1, 1, 0.65, 0.65,
0.15, 0.75, 0.875, 0.4875, 0.56875, 0.375, 0.4375, 0.225, 0.2625, 0.1125,
0.13125, 0.5, 0.75, 0.325, 0.4875, 0.25, 0.375, 0.15, 0.225, 0.075, 0.1125,
0.25, 0.625, 0.1625, 0.40625, 0.125, 0.3125, 0.075, 0.1875, 0.0375, 0.09375,
0, 0.5, 0, 0.325, 0, 0.25, 0, 0.15, 0, 0.075, 0, 0.5, 0, 0.325, 0, 0.25, 0,
0.15, 0, 0.075, 0, 0.5, 0, 0.325, 0, 0.25, 0, 0.15, 0, 0.075, 0, 0.5, 0,
0.325, 0, 0.25, 0, 0.15, 0, 0.075, 0, 0.5, 0, 0.325, 0, 0.25, 0, 0.15, 0,
0.075, 0, 0.5, 0, 0.325, 0, 0.25, 0, 0.15, 0, 0.075, 0, 0.5, 0, 0.325, 0,
0.25, 0, 0.15, 0, 0.075, 0, 0.5, 0, 0.325, 0, 0.25, 0, 0.15, 0, 0.075, 0,
0.5, 0, 0.325, 0, 0.25, 0, 0.15, 0, 0.075, 0.25, 0.625, 0.1625, 0.40625,
0.125, 0.3125, 0.075, 0.1875, 0.0375, 0.09375, 0.5, 0.75, 0.325, 0.4875,
0.25, 0.375, 0.15, 0.225, 0.075, 0.1125, 0.75, 0.875, 0.4875, 0.56875,
0.375, 0.4375, 0.225, 0.2625, 0.1125, 0.13125, 1, 1, 0.65, 0.65, 0.5, 0.5,
0.3, 0.3, 0.15, 0.15, 1, 1, 0.65, 0.65, 0.5, 0.5, 0.3, 0.3, 0.15, 0.15, 1,
1, 0.65, 0.65, 0.5, 0.5, 0.3, 0.3, 0.15, 0.15, 1, 1, 0.65, 0.65, 0.5, 0.5,
0.3, 0.3, 0.15, 0.15, 0.33, 0.464, 0.598, 0.732, 0.866, 1}
Return Red(ACI) * 255
End Function
Function ACIBlue(ByRef ACI As Integer) As Integer
Dim Blue As Object
Blue = New Object() {0, 0, 0, 1, 1, 1, 1, 1, 1, 0, 0.5, 0, 0.325, 0,
0.15, 0, 0.075, 0, 0.5, 0, 0.325, 0, 0.25, 0, 0.15, 0, 0.075, 0, 0.5, 0, 0.3
0.25, 0, 0.15, 0, 0.075, 0.25, 0.625, 0.1625, 0.40625, 0.125, 0.3125, 0.075,
0.1875, 0.0375, 0.09375, 0.5, 0.75, 0.325, 0.4875, 0.25, 0.375, 0.15, 0.225,
0.075, 0.1125, 0.75, 0.875, 0.4875, 0.56875, 0.375, 0.4375, 0.225, 0.2625,
0.1125, 0.13125, 1, 1, 0.65, 0.65, 0.5, 0.5, 0.3, 0.3, 0.15, 0.15, 1, 1,
0.65, 0.65, 0.5, 0.5, 0.3, 0.3, 0.15, 0.15, 1, 1, 0.65, 65, 0.5, 0.5, 0.3,
0.3, 0.15, 0.15, 1, 1, 0.65, 0.65, 0.5, 0.5, 0.3, 0.3, 0.15, 0.15, 1, 1,
0.65, 0.65, 0.5, 0.5, 0.3, 0.3, 0.15, 0.15, 1, 1, 0.65, 0.65, 0.5, 0.5, 0.3,
0.3, 0.15, 0.15, 0.75, 0.875, 0.4875, 0.56875, 0.375, 0.4375, 0.225, 0.2625,
0.1125, 0.13125, 0.5, 0.75, 0.325, 0.4875, 0.25, 0.375, 0.15, 0.225, 0.075,
0.1125, 0.25, 0.625, 0.1625, 0.40625, 0.125, 0.3125, 0.075, 0.1875, 0.0375,
0.09375, 0.33, 0.464, 0.598, 0.732, 0.866, 1}
Return Blue(ACI) * 255
End Function
Function ACIGreen(ByRef ACI As Integer) As Integer
Dim Green As Object
Green = New Object() {0, 1, 1, 1, 0, 0, 1, 1, 1, 0, 0.5, 0, 0.325,
0, 0.25, 0, 0.15, 0, 0.075, 0.25, 0.625, 0.1625, 0.40625, 0.125, 0.3125,
0.075, 0.1875, 0.0375, 0.09375, 0.5, 0.75, 0.325, 0.4875, 0.25, 0.375, 0.15,
0.225, 0.075, 0.1125, 0.75, 0.875, 0.4875, 0.56875, 0.375, 0.4375, 0.225,
0.2625, 0.1125, 0.13125, 1, 1, 0.65, 0.65, 0.5, 0.5, 0.3, 0.3, 0.15, 0.15,
1, 1, 0.65, 0.65, 0.5, 0.5, 0.3, 0.3, 0.15, 0.15, 1, 1, 0.65, 0.65, 0.5,
0.5, 0.3, 0.3, 0.15, 0.15, 1, 1, 0.65, 0.65, 0.5, 0.5, 0.3, 0.3, 0.15, 0.15,
0.5, 0.3, 0.3, 0.15, 0.15, 0.75, 0.875, 0.4875, 0.56875, 0.375, 0.4375,
0.225, 0.2625, 0.1125, 0.13125, 0.5, 0.75, 0.325, 0.4875, 0.25, 0.375, 0.15,
0.225, 0.075, 0.1125, 0.25, 0.625, 0.1625, 0.40625, 0.125, 0.3125, 0.075,
0.1875, 0.0375, 0.09375, 0, 0.5, 0, 0.325, 0, 0.25, 0, 0.15, 0, 0.075, 0,
0.25, 0, 0.15, 0, 0.075, 0.33, 0.464, 0.598, 0.732, 0.866, 1}
Return Green(ACI) * 255
End Function
Private Sub nudACI_ValueChanged(ByVal sender As System.Object, ByVal e
As System.EventArgs) Handles nudACI.ValueChanged
On Error Resume Next
Me.nudACI.BackColor = Color.FromArgb(255, _
ACIRed(CInt(Me.nudACI.Value)), _
ACIGreen(CInt(Me.nudACI.Value)), _
ACIBlue(CInt(Me.nudACI.Value)))
End Sub
"Russ Green" wrote in message
news:D1F8BE90D4633C62355DEE34B7E729A0@in.WebX.maYIadrTaRb...
> color.
> Any ideas?
> Russ
Russ,
This code along with the included AcadToRGB function posted 12/23/2002 by
Kevin Terry does what you want.
Private Sub TextBox1_Change()
TextBox1.BackColor = AcadToRGB(TextBox1.Value)
End Sub
'Returns RGB equivalent to passed acad color index (ACI)
Public Function AcadToRGB(ByVal Col As Long) As Variant
Dim R As Long, G As Long, B As Long
Select Case Col
Case 1: AcadToRGB = 255: Exit Function
Case 2: AcadToRGB = 65535: Exit Function
Case 3: AcadToRGB = 65280: Exit Function
Case 4: AcadToRGB = 16776960: Exit Function
Case 5: AcadToRGB = 16711680: Exit Function
Case 6: AcadToRGB = 16711935: Exit Function
Case 7: AcadToRGB = 16777215: Exit Function
Case 8: AcadToRGB = 8355711: Exit Function
Case 9: AcadToRGB = 12566463: Exit Function
Case 10: AcadToRGB = 255: Exit Function
Case 11: AcadToRGB = 8355839: Exit Function
Case 12: AcadToRGB = 207: Exit Function
Case 13: AcadToRGB = 6316239: Exit Function
Case 14: AcadToRGB = 144: Exit Function
Case 15: AcadToRGB = 5197712: Exit Function
Case 16: AcadToRGB = 127: Exit Function
Case 90, 92, 94, 96, 98, 100, 102, 104, 106, 108, 110, 112, 114,
116, 118, _
120, 122, 124, 126, 128, 130, 132, 134, 136, 138, 140, 142, 144,
146, 148, _
150, 152, 154, 156, 158, 160, 162, 164, 166, 168, 170, 172, 174,
176, 178: R = 0
Case 88, 188: R = 15
Case 86, 186: R = 31
Case 78, 84, 99, 109, 119, 129, 139, 149, 159, 169, 179, 184, 198: R
= 32
Case 82, 89, 182, 189, 250: R = 47
Case 68, 79, 199, 208: R = 48
Case 69, 76, 80, 97, 107, 117, 127, 137, 147, 157, 167, 177, 180,
196, 209: R = 63
Case 18, 19, 28, 29, 38, 39, 48, 49, 58, 59, 74, 87, 95, 105, 115,
125, 135, _
145, 155, 165, 175, 187, 194, 218, 219, 228, 229, 238, 239, 248,
249: R = 79
Case 66, 77, 185, 197, 206: R = 95
Case 72, 85, 93, 103, 113, 123, 133, 143, 153, 163, 173, 192: R = 96
Case 64, 67, 75, 195, 204, 207: R = 111
Case 17, 26, 27, 36, 37, 46, 47, 56, 57, 70, 83, 91, 101, 111, 121,
131, _
141, 151, 161, 171, 183, 190, 216, 217, 226, 227, 236, 237, 246,
247: R = 127
Case 65, 205, 252: R = 128
Case 24, 25, 34, 35, 44, 45, 54, 55, 62, 73, 193, 202, 214, 215,
224, 225, _
234, 235, 244, 245: R = 144
Case 81, 181: R = 159
Case 63, 203, 253: R = 175
Case 60, 71, 191, 200: R = 191
Case 22, 23, 32, 33, 42, 43, 52, 53, 212, 213, 222, 223, 232, 233,
242, 243: R = 207
Case 61, 201: R = 223
Case 20, 21, 30, 31, 40, 41, 50, 51, 210, 211, 220, 221, 230, 231,
240, 241, 255: R = 255
Case 251: R = 80: G = 80: B = 80
Case 254: R = 208: G = 208: B = 208
End Select
Select Case Col
Case 18, 170, 172, 174, 176, 178, 180, 182, 184, 186, 188, 190, 192,
194, _
196, 198, 200, 202, 204, 206, 208, 210, 212, 214, 216, 218, 220,
222, 224, _
226, 228, 230, 232, 234, 236, 238, 240, 242, 244, 246, 248: G =
0
Case 28, 168: G = 15
Case 26, 166: G = 31
Case 19, 24, 38, 158, 164, 179, 189, 199, 209, 219, 229, 239, 249: G
= 32
Case 22, 29, 162, 169, 250: G = 47
Case 39, 48, 148, 159: G = 48
Case 17, 20, 36, 49, 149, 156, 160, 177, 187, 197, 207, 217, 227,
237, 247: G = 63
Case 18, 27, 34, 58, 59, 68, 69, 78, 79, 88, 89, 98, 99, 108, 109,
118, 119, _
128, 129, 138, 139, 154, 167, 175, 185, 195, 205, 215, 225, 235,
245: G = 79
Case 152: G = 86
Case 25, 37, 46, 146, 157, 165: G = 95
Case 32, 173, 183, 193, 203, 213, 223, 233, 243: G = 96
Case 35, 44, 47, 144, 147, 155: G = 111
Case 23, 30, 56, 57, 66, 67, 76, 77, 86, 87, 96, 97, 106, 107, 116,
117, _
126, 127, 136, 137, 150, 163, 171, 181, 191, 201, 211, 221, 231,
241: G = 127
Case 45, 145, 252: G = 128
Case 33, 42, 54, 55, 64, 65, 74, 75, 84, 85, 94, 95, 104, 105, 114,
115, _
124, 125, 134, 135, 142, 153: G = 144
Case 21, 161: G = 159
Case 43, 143, 253: G = 175
Case 31, 40, 140, 151: G = 191
Case 52, 53, 62, 63, 72, 73, 82, 83, 92, 93, 102, 103, 112, 113,
122, 123, _
132, 133: G = 207
Case 41, 141: G = 223
Case 50, 51, 60, 61, 70, 71, 80, 81, 90, 91, 100, 101, 110, 111,
120, 121, _
130, 131, 255: G = 255
End Select
Select Case Col
Case 18, 20, 22, 24, 26, 28, 30, 32, 34, 36, 38, 40, 42, 44, 46, 48,
50, 52, _
54, 56, 58, 60, 62, 64, 66, 68, 70, 72, 74, 76, 78, 80, 82, 84,
86, 88, 90, _
92, 94, 96, 98: B = 0
Case 108, 248: B = 15
Case 106, 246: B = 31
Case 19, 29, 39, 49, 59, 69, 79, 89, 99, 104, 118, 238, 244: B = 32
Case 102, 109, 242, 249, 250: B = 47
Case 119, 128, 228, 239: B = 48
Case 17, 27, 37, 47, 57, 67, 77, 87, 97, 100, 116, 129, 229, 236,
240: B = 63
Case 25, 35, 45, 55, 65, 75, 85, 95, 107, 114, 138, 139, 148, 149,
158, 159, _
168, 169, 178, 179, 188, 189, 198, 199, 208, 209, 218, 219, 234,
247: B = 79
Case 105, 117, 126, 226, 237, 245: B = 95
Case 23, 33, 43, 53, 63, 73, 83, 93, 112, 232: B = 96
Case 115, 124, 127, 224, 227, 235: B = 111
Case 21, 31, 41, 51, 61, 71, 81, 91, 103, 110, 136, 137, 146, 147,
156, 157, _
166, 167, 176, 177, 186, 187, 196, 197, 206, 207, 216, 217, 230,
243: B = 127
Case 125, 225, 252: B = 128
Case 113, 122, 134, 135, 144, 145, 154, 155, 164, 165, 174, 175,
184, 185, _
194, 195, 204, 205, 214, 215, 222, 233: B = 144
Case 101, 241: B = 159
Case 123, 223, 253: G = 175
Case 111, 120, 220, 231: B = 191
Case 132, 133, 142, 143, 152, 153, 162, 163, 172, 173, 182, 183,
192, 193, _
202, 203, 212, 213: B = 207
Case 121: B = 223
Case 130, 131, 140, 141, 150, 151, 160, 161, 170, 171, 180, 181,
190, 191, _
200, 201, 210, 211, 221, 255: B = 255
End Select
AcadToRGB = RGB(R, G, B)
End Function
> color.
> Any ideas?
> Russ
In VB.NET to use RGB you must do this...
Private Sub nudACI_ValueChanged(ByVal sender As System.Object, _
ByVal e As System.EventArgs) Handles nudACI.ValueChanged
Me.nudACI.BackColor = System.Drawing.ColorTranslator.FromOle _
(CInt(AcadToRgb(CInt(Me.nudACI.Value))))
End Sub
Russ
"Jeff Mishler" wrote in message
news:DAA9327D2B2525795B9E4CE00585AB71@in.WebX.maYIadrTaRb...
> Russ,
> End Sub
> Select Case Col
> 116, 118, _
144,
> 146, 148, _
174,
> 176, 178: R = 0
R
> = 32
> 196, 209: R = 63
> 125, 135, _
248,
> 249: R = 79
96
121,
> 131, _
246,
> 247: R = 127
> 224, 225, _
> 242, 243: R = 207
> End Select
> Select Case Col
192,
> 194, _
220,
> 222, 224, _
> 0
G
> = 32
> 237, 247: G = 63
> 118, 119, _
235,
> 245: G = 79
> Case 152: G = 86
116,
> 117, _
231,
> 241: G = 127
114,
> 115, _
> 122, 123, _
> 132, 133: G = 207
> 120, 121, _
> End Select
> Select Case Col
48,
> 50, 52, _
84,
> 86, 88, 90, _
32
> 240: B = 63
> 158, 159, _
234,
> 247: B = 79
> 156, 157, _
230,
> 243: B = 127
> 184, 185, _
> 192, 193, _
> Case 121: B = 223
> 190, 191, _
> End Select
> End Function
this
> > color.
> > Any ideas?
> > Russ
This is a slightly cleaner function....
Public Function AcColorToRgb(ByVal iColor As Integer) As Long
Dim lColorOut As Long
Select Case iColor
'Case acByLayer : lColorOut = vbWhite
'Case acByBlock : lColorOut = vbWhite
Case 1 : lColorOut = 255 'red
Case 2 : lColorOut = 65535 'yellow
Case 3 : lColorOut = 65280
Case 4 : lColorOut = 16776960
Case 5 : lColorOut = 16711680
Case 6 : lColorOut = 16711935
Case 7 : lColorOut = 16777215
Case 8 : lColorOut = 8421504
Case 9 : lColorOut = 12632256
Case 10 : lColorOut = 255
Case 11 : lColorOut = 8355839
Case 12 : lColorOut = 204
Case 13 : lColorOut = 6710988
Case 14 : lColorOut = 153
Case 15 : lColorOut = 5000345
Case 16 : lColorOut = 127
Case 17 : lColorOut = 4145023
Case 18 : lColorOut = 77
Case 19 : lColorOut = 2500172
Case 20 : lColorOut = 16383
Case 21 : lColorOut = 8364031
Case 22 : lColorOut = 13260
Case 23 : lColorOut = 6717388
Case 24 : lColorOut = 9881
Case 25 : lColorOut = 5005209
Case 26 : lColorOut = 8063
Case 27 : lColorOut = 4149119
Case 28 : lColorOut = 4940
Case 29 : lColorOut = 2502476
Case 30 : lColorOut = 32767
Case 31 : lColorOut = 8372223
Case 32 : lColorOut = 26316
Case 33 : lColorOut = 6724044
Case 34 : lColorOut = 19609
Case 35 : lColorOut = 5010073
Case 36 : lColorOut = 16255
Case 37 : lColorOut = 4153215
Case 38 : lColorOut = 9804
Case 39 : lColorOut = 2505036
Case 40 : lColorOut = 49151
Case 41 : lColorOut = 8380415
Case 42 : lColorOut = 39372
Case 43 : lColorOut = 6730444
Case 44 : lColorOut = 29337
Case 45 : lColorOut = 5014937
Case 46 : lColorOut = 24447
Case 47 : lColorOut = 4157311
Case 48 : lColorOut = 14668
Case 49 : lColorOut = 2507340
Case 50 : lColorOut = 65535
Case 51 : lColorOut = 8388607
Case 52 : lColorOut = 52428
Case 53 : lColorOut = 6737100
Case 54 : lColorOut = 39321
Case 55 : lColorOut = 5020057
Case 56 : lColorOut = 32639
Case 57 : lColorOut = 4161407
Case 58 : lColorOut = 19532
Case 59 : lColorOut = 2509900
Case 60 : lColorOut = 65471
Case 61 : lColorOut = 8388575
Case 62 : lColorOut = 52377
Case 63 : lColorOut = 6737074
Case 64 : lColorOut = 39282
Case 65 : lColorOut = 5020037
Case 66 : lColorOut = 32607
Case 67 : lColorOut = 4161391
Case 68 : lColorOut = 19513
Case 69 : lColorOut = 2509890
Case 70 : lColorOut = 65407
Case 71 : lColorOut = 8388543
Case 72 : lColorOut = 52326
Case 73 : lColorOut = 6737049
Case 74 : lColorOut = 39244
Case 75 : lColorOut = 5020018
Case 76 : lColorOut = 32575
Case 77 : lColorOut = 4161375
Case 78 : lColorOut = 19494
Case 79 : lColorOut = 2509881
Case 80 : lColorOut = 65343
Case 81 : lColorOut = 8388511
Case 82 : lColorOut = 52275
Case 83 : lColorOut = 6737023
Case 84 : lColorOut = 39206
Case 85 : lColorOut = 5019999
Case 86 : lColorOut = 32543
Case 87 : lColorOut = 4161359
Case 88 : lColorOut = 19475
Case 89 : lColorOut = 2509871
Case 90 : lColorOut = 65280
Case 91 : lColorOut = 8388479
Case 92 : lColorOut = 52224
Case 93 : lColorOut = 6736998
Case 94 : lColorOut = 39168
Case 95 : lColorOut = 5019980
Case 96 : lColorOut = 32512
Case 97 : lColorOut = 4161343
Case 98 : lColorOut = 19456
Case 99 : lColorOut = 2509862
Case 100 : lColorOut = 4194048
Case 101 : lColorOut = 10485631
Case 102 : lColorOut = 3394560
Case 103 : lColorOut = 8375398
Case 104 : lColorOut = 2529536
Case 105 : lColorOut = 6265164
Case 106 : lColorOut = 2064128
Case 107 : lColorOut = 5209919
Case 108 : lColorOut = 1264640
Case 109 : lColorOut = 3099686
Case 110 : lColorOut = 8388352
Case 111 : lColorOut = 12582783
Case 112 : lColorOut = 6736896
Case 113 : lColorOut = 10079334
Case 114 : lColorOut = 5019904
Case 115 : lColorOut = 7510348
Case 116 : lColorOut = 4161280
Case 117 : lColorOut = 6258495
Case 118 : lColorOut = 2509824
Case 119 : lColorOut = 3755046
Case 120 : lColorOut = 12582656
Case 121 : lColorOut = 14679935
Case 122 : lColorOut = 10079232
Case 123 : lColorOut = 11717734
Case 124 : lColorOut = 7510272
Case 125 : lColorOut = 8755532
Case 126 : lColorOut = 6258432
Case 127 : lColorOut = 7307071
Case 128 : lColorOut = 3755008
Case 129 : lColorOut = 4344870
Case 130 : lColorOut = 16776960
Case 131 : lColorOut = 16777087
Case 132 : lColorOut = 13421568
Case 133 : lColorOut = 13421670
Case 134 : lColorOut = 10066176
Case 135 : lColorOut = 10066252
Case 136 : lColorOut = 8355584
Case 137 : lColorOut = 8355647
Case 138 : lColorOut = 5000192
Case 139 : lColorOut = 5000230
Case 140 : lColorOut = 16760576
Case 141 : lColorOut = 16768895
Case 142 : lColorOut = 13408512
Case 143 : lColorOut = 13415014
Case 144 : lColorOut = 10056192
Case 145 : lColorOut = 10061132
Case 146 : lColorOut = 8347392
Case 147 : lColorOut = 8351551
Case 148 : lColorOut = 4995328
Case 149 : lColorOut = 4997670
Case 150 : lColorOut = 16744192
Case 151 : lColorOut = 16760703
Case 152 : lColorOut = 13395456
Case 153 : lColorOut = 13408614
Case 154 : lColorOut = 10046464
Case 155 : lColorOut = 10056268
Case 156 : lColorOut = 8339200
Case 157 : lColorOut = 8347455
Case 158 : lColorOut = 4990464
Case 159 : lColorOut = 4995366
Case 160 : lColorOut = 16727808
Case 161 : lColorOut = 16752511
Case 162 : lColorOut = 13382400
Case 163 : lColorOut = 13401958
Case 164 : lColorOut = 10036736
Case 165 : lColorOut = 10051404
Case 166 : lColorOut = 8331008
Case 167 : lColorOut = 8343359
Case 168 : lColorOut = 4985600
Case 169 : lColorOut = 4992806
Case 170 : lColorOut = 16711680
Case 171 : lColorOut = 16744319
Case 172 : lColorOut = 13369344
Case 173 : lColorOut = 13395558
Case 174 : lColorOut = 10027008
Case 175 : lColorOut = 10046540
Case 176 : lColorOut = 8323072
Case 177 : lColorOut = 8339263
Case 178 : lColorOut = 4980736
Case 179 : lColorOut = 4990502
Case 180 : lColorOut = 16711743
Case 181 : lColorOut = 16744351
Case 182 : lColorOut = 13369395
Case 183 : lColorOut = 13395583
Case 184 : lColorOut = 10027046
Case 185 : lColorOut = 10046559
Case 186 : lColorOut = 8323103
Case 187 : lColorOut = 8339279
Case 188 : lColorOut = 4980755
Case 189 : lColorOut = 4990511
Case 190 : lColorOut = 16711807
Case 191 : lColorOut = 16744383
Case 192 : lColorOut = 13369446
Case 193 : lColorOut = 13395609
Case 194 : lColorOut = 10027084
Case 195 : lColorOut = 10046578
Case 196 : lColorOut = 8323135
Case 197 : lColorOut = 8339295
Case 198 : lColorOut = 4980774
Case 199 : lColorOut = 4990521
Case 200 : lColorOut = 16711871
Case 201 : lColorOut = 16744415
Case 202 : lColorOut = 13369497
Case 203 : lColorOut = 13395634
Case 204 : lColorOut = 10027122
Case 205 : lColorOut = 10046597
Case 206 : lColorOut = 8323167
Case 207 : lColorOut = 8339311
Case 208 : lColorOut = 4980793
Case 209 : lColorOut = 4990530
Case 210 : lColorOut = 16711935
Case 211 : lColorOut = 16744447
Case 212 : lColorOut = 13369548
Case 213 : lColorOut = 13395660
Case 214 : lColorOut = 10027161
Case 215 : lColorOut = 10046617
Case 216 : lColorOut = 8323199
Case 217 : lColorOut = 8339327
Case 218 : lColorOut = 4980812
Case 219 : lColorOut = 4990540
Case 220 : lColorOut = 12517631
Case 221 : lColorOut = 14647295
Case 222 : lColorOut = 10027212
Case 223 : lColorOut = 11691724
Case 224 : lColorOut = 7471257
Case 225 : lColorOut = 8735897
Case 226 : lColorOut = 6226047
Case 227 : lColorOut = 7290751
Case 228 : lColorOut = 3735628
Case 229 : lColorOut = 4335180
Case 230 : lColorOut = 8323327
Case 231 : lColorOut = 12550143
Case 232 : lColorOut = 6684876
Case 233 : lColorOut = 10053324
Case 234 : lColorOut = 4980889
Case 235 : lColorOut = 7490713
Case 236 : lColorOut = 4128895
Case 237 : lColorOut = 6242175
Case 238 : lColorOut = 2490444
Case 239 : lColorOut = 3745356
Case 240 : lColorOut = 4129023
Case 241 : lColorOut = 10452991
Case 242 : lColorOut = 3342540
Case 243 : lColorOut = 8349388
Case 244 : lColorOut = 2490521
Case 245 : lColorOut = 6245529
Case 246 : lColorOut = 2031743
Case 247 : lColorOut = 5193599
Case 248 : lColorOut = 1245260
Case 249 : lColorOut = 3089996
Case 250 : lColorOut = 3355443
Case 251 : lColorOut = 5987163
Case 252 : lColorOut = 8684676
Case 253 : lColorOut = 11382189
Case 254 : lColorOut = 14079702
Case 255 : lColorOut = 16777215 'Gray
End Select
Return lColorOut
End Function
news:E6AD69E54B8EFE92ECA8A7EACA400081@in.WebX.maYIadrTaRb...
> Thanks
> End Sub
> Russ
> > Russ,
by
> > End Sub
> > Select Case Col
> > 116, 118, _
> 144,
> > 146, 148, _
> 174,
> > 176, 178: R = 0
198:
> R
> > = 32
180,
> > 196, 209: R = 63
115,
> > 125, 135, _
> 248,
> > 249: R = 79
> 96
> 121,
> > 131, _
> 246,
> > 247: R = 127
> > 224, 225, _
233,
> > 242, 243: R = 207
231,
> > End Select
> > Select Case Col
> 192,
> > 194, _
> 220,
> > 222, 224, _
G
> > 0
249:
> G
> > = 32
227,
> > 237, 247: G = 63
109,
> > 118, 119, _
> 235,
> > 245: G = 79
> > Case 152: G = 86
> 116,
> > 117, _
> 231,
> > 241: G = 127
> 114,
> > 115, _
> > 122, 123, _
> > 132, 133: G = 207
> > 120, 121, _
> > End Select
> > Select Case Col
> 48,
> > 50, 52, _
> 84,
> > 86, 88, 90, _
> 32
236,
> > 240: B = 63
149,
> > 158, 159, _
> 234,
> > 247: B = 79
147,
> > 156, 157, _
> 230,
> > 243: B = 127
> > 184, 185, _
> > 192, 193, _
> > Case 121: B = 223
> > 190, 191, _
> > End Select
> > End Function
color
> this
> > > color.
> > > Any ideas?
> > > Russ
Russ, if you're using acad 2004 there is a new TrueColor object that you can
use to do this conversion for you.
Bobby C. Jones
www.AcadX.com
> color.
> Any ideas?
> Russ
Not using 2004 yet just programming for 2002 right now.
Russ
"Bobby C. Jones" wrote in message
news:ABFF5E8B58AB06889264CD7BB1786AEC@in.WebX.maYIadrTaRb...
can
> Bobby C. Jones
> www.AcadX.com
this
> > color.
> > Any ideas?
> > Russ
