Problems with attaching Xdata to a Layer and then retrieving the xdata
Hi everyone,
I am working on a program that will iterate through a drawings layers and convert the colours of each layer from our company standard to a client standard. I can do all this without any problems but I want to make sure that if the extar layers are added to the drawing, the program will ignore any layers that had been previously converted.
I thought that xdata would be the most appropiate way to do this. Below are the steps I want the program to do:-
1. Cycle through each layer. If xdata exists with string "converted_previously" goto next layer, Else go to step 2
2. Convert layer colours to client standard. Attach xdata to layer to ensure it does not get converted twice
I think that the xdata is being attached to the layer but I cannot appear to retrieve the xdata and place it in a variable. Below is the code I'm trying to use in relation to the xdata:-
Public Sub LAYER_COLOUR_CHECK()
Dim LAYER As AcadLayer
Dim LAYER_COLLECTION As AcadLayers
Dim LAYER_XDATA_TYPE(0 To 1) As Integer
Dim LAYER_XDATA(0 To 1) As Variant
Dim LAYER_XDATA_TYPE_RETRIEVED As Integer
Dim LAYER_XDATA_RETRIEVED As String
' Assign Values to variables for xdata
LAYER_XDATA_TYPE(0) = 1001: LAYER_XDATA(0) = "LAYER_CHECK_APP"
LAYER_XDATA_TYPE(1) = 1000: LAYER_XDATA(1) = "LAYER_CONVERSION_DONE"
Set LAYER_COLLECTION = ThisDrawing.Layers
For Each LAYER In LAYER_COLLECTION
' Attach xdata to LAYER
LAYER.SetXData LAYER_XDATA_TYPE, LAYER_XDATA
' Retrieve Xdata from LAYER
LAYER.GetXData "LAYER_CHECK_APP", LAYER_XDATA_TYPE_RETRIEVED, LAYER_XDATA_RETRIEVED
ThisDrawing.Utility.Prompt ("XDATA TYPE = " & LAYER_XDATA_TYPE_RETRIEVED) & vbCrLf
ThisDrawing.Utility.Prompt ("XDATA = " & LAYER_XDATA_RETRIEVED) & vbCrLf
If LAYER_XDATA_RETRIEVED = "LAYER_CONVERSION_DONE" Then
ThisDrawing.Utility.Prompt (LAYER.Name & " has been converted previously")
GoTo NEXT_LAYER
Else
ThisDrawing.Utility.Prompt (LAYER.Name & " has not been converted") & vbCrLf
NEXT_LAYER:
Next LAYER
End Sub
Below is what is shown on the command line when I run the program
XDATA TYPE = 0
XDATA =
test layer 2 has not been converted
XDATA TYPE = 0
XDATA =
test layer 8 has not been converted
I cannot work out why I can't retrive the values for the xdata. Any help would be greatly appreciated.
Cheers,
Ian
Hi everyone I managed to get this to work.
The problem was that the program would fall over when I would call up an empty variable where the xdata was meant to be stored. What I have done is put an On Error Goto Statement which appears to have solved the problem. It's probably not the most elegant way of doing it but it worked. Here's the code below that appears to work if anyone else has a similar problem.
Public Sub XDATA_TEST()
' Create a layer
'Dim NEW_LAYER As AcadLayer
'Set NEW_LAYER = ThisDrawing.Layers.Add("XDATA_TEST")
Dim DataType(0 To 1) As Integer
Dim Data(0 To 1) As Variant
DataType(0) = 1001: Data(0) = "LAYER_CHECK_APP"
DataType(1) = 1000: Data(1) = "CONVERTED_PREVIOUSLY"
' Attach the xdata to the layer
'LAYER.SetXData DataType, Data
' Return the xdata for the layer
Dim xdataOut As Variant
Dim xtypeOut As Variant
LAYER.GetXData "LAYER_CHECK_APP", xtypeOut, xdataOut
On Error GoTo NO_XDATA
'MsgBox "For Layer " & LAYER.Name & ": Xdata Type = " & xtypeOut(1) & "; xdata string = " & xdataOut(1), vbInformation, "xdata test"
If xdataOut(1) = "CONVERTED_PREVIOUSLY" Then
ThisDrawing.Utility.Prompt ("Layer " & LAYER.Name & " has been converted previously") & vbCrLf
GoTo NEXT_LAYER
Else
ThisDrawing.Utility.Prompt ("Layer " & LAYER.Name & " needs to be converted to RTA format") & vbCrLf
NO_XDATA:
MsgBox "No xdata attached to layer " & LAYER.Name, vbInformation, "no xdata attached to layer"
Resume NEXT_LAYER
NEXT_LAYER:
Next LAYER
End Sub
Cheers,
Ian
