Problems with attaching Xdata to a Layer and then retrieving the xdata
10:11 PM
- Mute
- Permalink
- Report
Hi everyone,
I am working on a program that will iterate through a drawings layers and convert the colours of each layer from our company standard to a client standard. I can do all this without any problems but I want to make sure that if the extar layers are added to the drawing, the program will ignore any layers that had been previously converted.
I thought that xdata would be the most appropiate way to do this. Below are the steps I want the program to do:-
1. Cycle through each layer. If xdata exists with string "converted_previously" goto next layer, Else go to step 2
2. Convert layer colours to client standard. Attach xdata to layer to ensure it does not get converted twice
I think that the xdata is being attached to the layer but I cannot appear to retrieve the xdata and place it in a variable. Below is the code I'm trying to use in relation to the xdata:-
Public Sub LAYER_COLOUR_CHECK()
Dim LAYER As AcadLayer
Dim LAYER_COLLECTION As AcadLayers
Dim LAYER_XDATA_TYPE(0 To 1) As Integer
Dim LAYER_XDATA(0 To 1) As Variant
Dim LAYER_XDATA_TYPE_RETRIEVED As Integer
Dim LAYER_XDATA_RETRIEVED As String
' Assign Values to variables for xdata
LAYER_XDATA_TYPE(0) = 1001: LAYER_XDATA(0) = "LAYER_CHECK_APP"
LAYER_XDATA_TYPE(1) = 1000: LAYER_XDATA(1) = "LAYER_CONVERSION_DONE"
Set LAYER_COLLECTION = ThisDrawing.Layers
For Each LAYER In LAYER_COLLECTION
' Attach xdata to LAYER
LAYER.SetXData LAYER_XDATA_TYPE, LAYER_XDATA
' Retrieve Xdata from LAYER
LAYER.GetXData "LAYER_CHECK_APP", LAYER_XDATA_TYPE_RETRIEVED, LAYER_XDATA_RETRIEVED
ThisDrawing.Utility.Prompt ("XDATA TYPE = " & LAYER_XDATA_TYPE_RETRIEVED) & vbCrLf
ThisDrawing.Utility.Prompt ("XDATA = " & LAYER_XDATA_RETRIEVED) & vbCrLf
If LAYER_XDATA_RETRIEVED = "LAYER_CONVERSION_DONE" Then
ThisDrawing.Utility.Prompt (LAYER.Name & " has been converted previously")
GoTo NEXT_LAYER
Else
ThisDrawing.Utility.Prompt (LAYER.Name & " has not been converted") & vbCrLf
End If
NEXT_LAYER:
Next LAYER
End Sub
Below is what is shown on the command line when I run the program
XDATA TYPE = 0
XDATA =
test layer 2 has not been converted
XDATA TYPE = 0
XDATA =
test layer 8 has not been converted
I cannot work out why I can't retrive the values for the xdata. Any help would be greatly appreciated.
Cheers,
Ian
GoTo NEXT_LAYER
Else
End If
NEXT_LAYER:
Next LAYER
End Sub
XDATA TYPE = 0
XDATA =
XDATA TYPE = 0
XDATA =
Cheers,
Ian
