How to read & write xml elements into Autocad
Message 1 of 11
Group,
I was wondering if someone could help me locate information related to xml
for use with drawing elements. I've searched all over the net and other than
landxml site I have yet to find any samples that show how to export drawings
elements to xml or control drawing elements from an xml file. The only data
I've found shows how to use the Landxml routines for input & export and I
want to see is if I can control placement of drawing elements linked by xml
if possible. I have several hundred routines which do a good job but to take
them to the next level of usability I'd like to see if I could write data
from these routines out to xml format so they could be used by other
utilities. as an example most of my routines use a baseline (two know
points) like an alignment in LDT where I select the same control points over
and over for processing the routines, I'd like to see if with the use of
xml I could possible link a project connection like LDT does where the
routines would know the controls points after a project have been created
and be able to toggle between several control points with N,E and N,E,Z.
My ultimate goal is to write most of our project data into xml file so that
it could not only be used by the vba utilities but also in our specs and
documents. I'll take any samples so that I can learn how to write data out
from a routine (xml) and be able to reuse that in tables, be able to input
blocks like the wblock xml or even draw polylines, lines
Any help, links, books, where to look for this type of information is
appreciated.
Thank you for your time & consideration
John
Replies (10)
Message 2 of 11
dgorsman
Check out the MSXML documentation on MSDN. Have you read the W3C documentation on the XML standards?
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Message 3 of 11
sample drawing,
could I reproduce the linework in this drawing or move the endpoints with an
xml file?
could I reproduce the location and or offsets of the blocks with an xml
file?
could I link the start and end points (ones with leaders) so a form could
read from an xml file?
"Jcoon" wrote in message
news:5750406@discussion.autodesk.com...
Group,
appreciated.
John
Message 4 of 11
dgorsman,
no not yet. This is my first look at xml other than using landxml from LDT &
C3D
John
wrote in message news:5750440@discussion.autodesk.com...
Message 5 of 11
The answer to all your questions is yes.
But you will need to have a suitable schema for the XML file.
The Land XML schema is only one of thousands of schemas and is not suitable
for drafting data.
I have some vague memory reading about a drafting schema and you are sure to
find something with a web search.
However, you could invent your own if the data is only to be used internally
and does not have to relate with other software using a defined schema.
Laurie Comerford
CADApps
www.cadapps.com.au
www.civil3Dtools.com
news:5750442@discussion.autodesk.com...
sample drawing,
xml file?
file?
Group,
ould write data
appreciated.
ration
John
Message 6 of 11
Laurie,
ok I'm ready, where should I look?
any books,blogs....links. This is my first try with xml simpler might be
better
John
"Laurie Comerford" wrote in message
news:5750639@discussion.autodesk.com...
for drafting data.
Laurie Comerford
CADApps
www.cadapps.com.au
sample drawing,
xml file?
file?
Group,
ould write data
appreciated.
ration
John
Message 7 of 11
dgorsman
Start from scratch - learn about the XML format and how it works first. You can skim the W3C standards, they simply define the XML format and what values can be used. The MSXML documentation is *very* important, thats the interface you will be using (unless you write your own, which I don't recommend). Once you have that, you can have a look at what you need to store and how it will be accessed. That may take a couple of passes. After all that, you can start outlining program flow.
Sounds a little long winded (learning the good stuff rarely is), but you will get better, longer lasting results than the hack and slash machete code generated by web cut 'n' paste.
Message 8 of 11
dgorsman,
I am going to try and learn xml but first I wanted to see if I got comments
from my questions & samples that indicated I could do some of the things I
wanted before I ran off trying to do something I couldn't do.
John
wrote in message news:5750890@discussion.autodesk.com...
Message 9 of 11
dgorsman
Yes, you can, but it will be a complex task.
Message 10 of 11
You don't have to post a sample file. The answer to your questions are all "yes", but you seem to be confusing XML files with applications/code or APIs that read and write XML files.
There is no existing application; code; or API that you can use, that is going to magically transform AutoCAD entities into XML, or the inverse. You must write the code that does that.
XML is just a file format. It's a tool programmers use to store data in a persistable/remotable form. That's all XML is. What you do with it is up to you, and anything you do with it requires you to be familiar with the XML format; how to design a schemas and transforms; how to read and write XML files from code, and so on.
LandXML is just a file format/schema that allows applications to write data in a form that other LandXML-enabled applications can read. LandXML, or the .XML file that contains LandXML data is not what does the actual work of reading data of AutoCAD or Civil3D objects and writing them to the XML stream. That is done by a lot of code in Civil3D.
And similarly, if you invent "JCoonsXML", that contains whatever information you want to store there, you must also write the code that reads and writes that data. IOW, an "XML file" does not do all of that for you, and there is no existing code/API that can do that for you either.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2008
Supporting AutoCAD 2000 through 2008
http://www.acadxtabs.com
"Jcoon" wrote in message news:5750442@discussion.autodesk.com...
sample drawing,
xml file?
file?
Group,
ould write data
appreciated.
ration
John
Message 11 of 11
Hi John,
A Google search for "xml for CAD data" will give you some further background
on Tony's expanations.
If you picture the XML file as simply another "database" file with (Trained)
human readable data, you can make a decision whether it is a good format for
storing your data.
Tony could tell you about .NET programming, but VBA programming to
read/write XML files is more complex than the programming to store the data
in a conventional SQL enabled database (such as Access) and in my
experience, data writing and data reading with XML are slower than using a
database. Geometric data for lines etc. can be easily stored in the AutoCAD
dwg (when is another database designed by Autodesk for holding this type of
data).
Regards
Laurie Comerford
Regards
Laurie Comerford
"Tony Tanzillo" wrote in message
news:5872010@discussion.autodesk.com...
sample drawing,
xml file?
file?
Group,
ould write data
appreciated.
ration
John
