Problem with selectionset
can anybody tell me why is it the Count =0 instead of 3?
Public Sub test()
Dim selSet As AcadSelectionSet
Dim FType As Variant
Dim FData As Variant
Dim PLObject As AcadPolyline
ReDim FType(1) As Integer
ReDim FData(1) As Variant
If ThisDrawing.SelectionSets.Count = 0 Then Set selSet = ThisDrawing.SelectionSets.Add("New") Else Set selSet = ThisDrawing.SelectionSets(0)
selSet.Clear
FType(0) = 0: FData(0) = "POLYLINE"
FType(1) = 8: FData(1) = "Pline"
Call selSet.Select(acSelectionSetAll, , , FType, FData)
Set PLObject = selSet(0)
selSet.Clear
ReDim FType(2) As Integer
ReDim FData(2) As Variant
FType(0) = 0: FData(0) = "TEXT"
FType(1) = 1: FData(1) = "xy"
FType(2) = 8: FData(2) = "Text"
Call selSet.SelectByPolygon(acSelectionSetCrossingPolygon, PLObject.Coordinates, FType, FData)
Debug.Print ("Count: " + CStr(selSet.Count))
End Sub
Thanks!
szab0a
Hi szab0a,
The data returned by your code is drawing specific. Hence only you
could possibly know by examining the data in your drawing.
Note that as you've posted it the code is missing an "End If"
It would be a lot easier to handle your query if you enclose the code in
makers like:
'' Place your code here.
Regards
Laurie Comerford
szab0a wrote:
> Hi, can anybody tell me why is it the Count =0 instead of 3? Public Sub
> test() Dim selSet As AcadSelectionSet Dim FType As Variant Dim FData As
> Variant Dim PLObject As AcadPolyline ReDim FType(1) As Integer ReDim
> FData(1) As Variant If ThisDrawing.SelectionSets.Count = 0 Then Set
> ThisDrawing.SelectionSets(0) selSet.Clear FType(0) = 0: FData(0) =
> "POLYLINE" FType(1) = 8: FData(1) = "Pline" Call
> selSet.Select(acSelectionSetAll, , , FType, FData) Set PLObject =
> selSet(0) selSet.Clear ReDim FType(2) As Integer ReDim FData(2) As
> Variant FType(0) = 0: FData(0) = "TEXT" FType(1) = 1: FData(1) = "xy"
> FType(2) = 8: FData(2) = "Text" Call
> PLObject.Coordinates, FType, FData) Debug.Print ("Count: " +
> CStr(selSet.Count)) End Sub Thanks! szab0a
Hi Laurie,
thanks for your answer.
I have my drawing attached in draw_2000.zip.
In my code isn't line bake, where if Then Else it.
Best Regards
szab0a
