Selection sequence bug in Autocad 2008 ?
Message 1 of 1
Hello, all
I found that Autocad 2008 returns somewhat arbitrary sequece when I choose object using VBA code below.
I found this does not occur in Autocad 2006 when tested with same drawing / DVB file.
I attached problematic autocd file and VBA code together in here.
I'll appreciate any trial and helpful advice.
( I choosed object in dwg file from TOP to DOWN using fence mode in Autocad . 1-2-3-4....
but program returns selectionset item in different sequence)
Dohkim
Replies (0)
