Problem with PlotToDevice
Hello all...
I am having problems with the .PlotToDevice
method.  I can't seem to change the CanonicalMediaName with any
results.
I am writing my own Batch Plot program in VB6 for
ACAD 2000.  The program lets you choose which files to plot and select the
size and printer.  We have used it successfully for years with R14 and I am
converting to 2000 now.  We don't use Paper Space and we are plotting with
.ctb files.  I am only trying to plot the model space.  We don't use
layouts either.  I am opening each drawing up in a read only
mode.
In the program I am really not sure if I am going
about it the right way.  I am using the ActiveLayout object.  I then
set some properties like ConfigName, CanonicalMediaName, StyleSheet, and so
on.
In my .pc3 file, I specify the plotter (say, an HP
Laserjet 4V) and there are many different available plot sizes to choose
from.  However when I specify the CanonicalMediaName in code it does not
use it, it only uses the default from the .pc3 file the last time it was
saved.
I tried doing a Regen to no avail.
I am pasting in the code below
(partial)...
size=2>        Case "C"
    'for a C
size drawing
With
myAcadDoc.ActiveLayout
.RefreshPlotDeviceInfo
.ConfigName =
strPC3File
.CanonicalMediaName =
strMediaName
.PaperUnits =
acInches
.PlotRotation =
ac90degrees
.PlotType =
acExtents
.StandardScale =
acScaleToFit
.PlotOrigin =
dblPlotOrigin
.PlotWithPlotStyles =
True
.StyleSheet = strPlotStyleDirectory &
strCTBFile
.PlotWithLineweights =
True
.PlotHidden =
False
End With
            f
= myAcadDoc.Plot.PlotToFile(PlotFileName, strPC3File)
  • color=#000000> Am i correct in using the ActiveLayout object or should I
    create a PlotConfiguration?
When
I don't specify the ConfigFileName in the PlotToFile method, there is no plot
created at all.
color=#000000>
I
know there is a lot of information here.  I appreciate any help.  I am
under the gun to get this working!!!
color=#000000>
Let me know if you need any more
info...
color=#000000>
color=#000000>Thanks
Jim
Shipley
I am not sure this is the only way but I set up a
different pc3 file for each paper size.
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Hello all...
results.
the size and printer.  We have used it successfully for years with R14
and I am converting to 2000 now.  We don't use Paper Space and we are
plotting with .ctb files.  I am only trying to plot the model
space.  We don't use layouts either.  I am opening each drawing up
in a read only mode.
on.
HP Laserjet 4V) and there are many different available plot sizes to choose
saved.
(partial)...
size=2>        Case "C"
    'for a C
size drawing
With
.ConfigName =
strPC3File
strMediaName
.PaperUnits =
acInches
.PlotRotation =
ac90degrees
.PlotType =
acExtents
.StandardScale =
acScaleToFit
.PlotOrigin =
dblPlotOrigin
True
strCTBFile
True
.PlotHidden =
False
End With
f = myAcadDoc.Plot.PlotToFile(PlotFileName, strPC3File)
    I create a PlotConfiguration?
color=#000000>When I don't specify the ConfigFileName in the PlotToFile
method, there is no plot created at all.
color=#000000>
I
am under the gun to get this working!!!
color=#000000>
info...
color=#000000>
color=#000000>Jim Shipley
Try removing the RefreshPlotDeviceInfo from the
end.  If it's a windows printer you may want to skip the pc3 file and plot
it by simply passing the windows printer name to it.
Rodney
McManamy - President
CADzation (formerly MACSolids)
Innovative CAD
Customization
AcroPlot(TM) - Plot multiple AutoCAD drawings to a
single
PDF document without using Adobe Acrobat.
website:
href="http://www.cadzation.com">www.cadzation.com
AcroPlot,
CADz3Dto2D, CADzation, CADzDesign, and CADzRelease are trademarks of
CADzation
Hello all...
results.
on.
saved.
(partial)...
size=2>        Case "C"
    'for a C
size drawing
With
.ConfigName =
strPC3File
strMediaName
.PaperUnits =
acInches
.PlotRotation =
ac90degrees
.PlotType =
acExtents
.StandardScale =
acScaleToFit
.PlotOrigin =
dblPlotOrigin
True
strCTBFile
True
.PlotHidden =
False
End With
color=#000000>
I
color=#000000>
info...
color=#000000>
serge
Hi Jim ... If you get a error on the media names, be sure to use the CORRECT media-names ... Did have the same problem ... use the following code to check out the names ...
Sub LIST_ALL_MEDIA_NAMES()
'List all the media names, and their localized version
Dim m_Teller As Integer
Dim m_MediaNames As Variant
ThisDrawing.ModelSpace.Layout.RefreshPlotDeviceInfo
m_MediaNames = ThisDrawing.ModelSpace.Layout.GetCanonicalMediaNames()
For m_Teller = LBound(m_MediaNames) To UBound(m_MediaNames)
frmListAllMediaNames.lst1.AddItem "_______________________________________"
frmListAllMediaNames.lst1.AddItem m_MediaNames(m_Teller)
frmListAllMediaNames.lst1.AddItem ThisDrawing.ModelSpace.Layout.GetLocaleMediaName(m_MediaNames(m_Teller))
'MsgBox m_MediaNames(m_Teller)
'MsgBox ThisDrawing.ModelSpace.Layout.GetLocaleMediaName(m_MediaNames(m_Teller))
Next
frmListAllMediaNames.Show
End Sub
... Hopes this helps, if not let me know ... Regards ... SMD
DEVIDTS Serge, CAD Consultant
http://www.CADdICT.be
Thanks!!
I also discovered this on my own.  After
checking the results of GetCanonicalMediaNames at various stages during the
program in break mode, I found that the RefreshPlotDeviceInfo was resetting
them.  I also used different .pc3 files for each size plot (even for the
same printer).  This seems to work so I will leave it.
Thanks again...
Jim Shipley
plot it by simply passing the windows printer name to it.
Rodney McManamy - President
CADzation (formerly
MACSolids)
Innovative CAD Customization
single
website:
AcroPlot,
CADzation
Hello all...
results.
for ACAD 2000.  The program lets you choose which files to plot and
select the size and printer.  We have used it successfully for years
with R14 and I am converting to 2000 now.  We don't use Paper Space and
we are plotting with .ctb files.  I am only trying to plot the model
going about it the right way.  I am using the ActiveLayout
object.  I then set some properties like ConfigName,
CanonicalMediaName, StyleSheet, and so on.
not use it, it only uses the default from the .pc3 file the last time it was
saved.
(partial)...
size=2>        Case "C"
    'for a C
size drawing
With
.ConfigName =
strPC3File
strMediaName
.PaperUnits =
acInches
.PlotRotation =
ac90degrees
.PlotType =
acExtents
.StandardScale =
acScaleToFit
.PlotOrigin =
dblPlotOrigin
True
strCTBFile
True
.PlotHidden =
False
End
With
            f
    should I create a PlotConfiguration?
color=#000000>
color=#000000>I know there is a lot of information here.  I appreciate
any help.  I am under the gun to get this
working!!!
color=#000000>
info...
color=#000000>
color=#000000>Jim
Shipley
I ended up doing this too...
Jim
Hello all...
results.
saved.
(partial)...
size=2>        Case "C"
    'for a C
size drawing
With
.ConfigName =
strPC3File
strMediaName
.PaperUnits =
acInches
.PlotRotation =
ac90degrees
.PlotType =
acExtents
.StandardScale =
acScaleToFit
.PlotOrigin =
dblPlotOrigin
True
strCTBFile
True
.PlotHidden =
False
End
With
            f
color=#000000>
working!!!
color=#000000>
info...
color=#000000>
color=#000000>Jim
Shipley
This I had correct, it was the
RefreshPlotDeviceInfo at the end that was screwing things up!
Jim Shipley
Hi
out the names ...
 'List all the media
 m_MediaNames
 For
  'MsgBox
 Next
End Sub
