RGB of the autocad colors?
Message 1 of 9
How can i retrieve the RGB values of each color index of Autocad in VBA ?
Thx a lot
Replies (8)
Message 2 of 9
Ed__Jobe
Try doing a search on this ng. There were a couple of suggestions a month or two back. -Ed
Ed
How to post your code.
Message 3 of 9
Just for the record, although several people
provided some functions to do this, and I found some
on the web, I found none of them returned
consistent values.  It seems that the RGB values may be
dependent somewhat on the drivers of the video
card.
Good luck.  If you find something that matches
consistently, I would love to know it...
Brian D.
style="BORDER-LEFT: #000000 2px solid; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px; PADDING-LEFT: 5px; PADDING-RIGHT: 0px">
Try
back. -Ed
Message 4 of 9
Well, for what its worth, here's mine... The
attached file is a form that I include in my projects that emulates the AutoCAD
color dialog box. It includes a routine that returns the RGB value. As for the
difference from machine to machine, I've never noticed one but that does not
mean it doesn't exist.
card.
matches consistently, I would love to know it...
Brian D.
Try
back. -Ed
Message 5 of 9
Thx a lot for your respones.
I've found a link with the correspondence between
Autocad colors and the RGB values.
It's in french sorry !
But my goal is to do the same grid than the layers
grid of autocad, with the color and the name of the layer in one
column.
Is anybody do already this? Thx again
AutoCAD color dialog box. It includes a routine that returns the RGB value. As
for the difference from machine to machine, I've never noticed one but that
does not mean it doesn't exist.
card.
Brian D.
Try
two back. -Ed
Message 6 of 9
I can't open your form cos it logs me a error
The property OleObjectBlob in frmColors
has got an incorrect file reference
Is it normal ?
card.
Brian D.
Try
two back. -Ed
Message 7 of 9
Yes, unfortunately it is normal. But only because
I'm an idiot. I forgot to send the .frx file with the form. You can download the
proper files here :
href="http://www.vbdesign.net/cadpages/community/colordialog.htm">http://www.vbdesign.net/cadpages/...
I would recommend downloading version 2. Version 1 is smaller in file size but
requires an additional class file. Version 2 is just simpler to include and use.
Once you have the form opened, there is an example of calling and using the form
that is commented out at the top of the file.
Message 8 of 9
Your code is very interesting. Thx a
lot
Can you send me the .bmp of your images plz 'cos i
want to do the same form but called from a vb program ?
the proper files here :
href="http://www.vbdesign.net/cadpages/community/colordialog.htm">http://www.vbdesign.net/cadpage...
use. Once you have the form opened, there is an example of calling and using
the form that is commented out at the top of the
file.
Message 9 of 9
You can take a screen shot of the one you have. I
files....
lot
i want to do the same form but called from a vb program ?
because I'm an idiot. I forgot to send the .frx file with the form. You can
download the proper files here :
href="http://www.vbdesign.net/cadpages/community/colordialog.htm">http://www.vbdesign.net/cadpa...
but requires an additional class file. Version 2 is just simpler to include
and use. Once you have the form opened, there is an example of calling and
using the form that is commented out at the top of the
file.
