Problem of writing lisps using excel vba
skchui6159
skchui6159
Sub RunTwoLispInSpecificAutoCADFile()
Dim acadApp As Object
Dim acadDoc As Object
Dim dwgPath As String
Dim lispCode1 As String
Dim lispCode2 As String
Dim lispCode3 As String
' Setting Path
dwgPath = "C:\Users\XXX\Desktop\Sample\6-1-2025\Drawing1.dwg"
' Use AUTOCAD Application to run
On Error Resume Next
Set acadApp = GetObject(, "AutoCAD.Application")
If Err.Number <> 0 Then
Set acadApp = CreateObject("AutoCAD.Application")
On Error GoTo 0
' Show AutoCAD
acadApp.Visible = True
' Opening DWG document
Set acadDoc = acadApp.Documents.Open(dwgPath)
' Running LISP
lispCode1 = "(command ""circle"" (list 5 0) 50 """" """")" ' LISP1
lispCode2 = "(command ""circle"" (list 5 0) 100 """" """")" ' LISP2"
lispCode3 = "(command ""circle"" (list 5 0) 200 """" """")" ' LISP3"
' LISP to AutoCAD
acadApp.ActiveDocument.SendCommand lispCode1 & vbCr
acadApp.ActiveDocument.SendCommand lispCode2 & vbCr
acadApp.ActiveDocument.SendCommand lispCode3 & vbCr
' Clear Ram if excel
Set acadDoc = Nothing
Set acadApp = Nothing
End Sub
Anyone know Why it doesn't works automatically in excel?
Ed__Jobe
It’s not helpful if you just say “it’s not working “. Give some details of what’s happening and what trouble shooting you did. What does AutoCAD’s command line history show? If you get something like UNKNOWN COMMAND then your lisp is probably not formatted correctly. Instead of double quotes, use the backslash escape character, e.g. \”.  But first you should be using the VBA api to add a circle. Use the AddCircle method.
Also, use the link in my signature to post your code in a code window to preserve the formatting.
Ed
How to post your code.
skchui6159
    ' Setting Path
    dwgPath = "C:\Users\xxxx\Desktop\Sample\6-1-2025\Drawing1.dwg"
    On Error GoTo 0
    ' Show AutoCAD
    ' Running LISP
'    lispCode1 = "(command ""circle"" (list 5 0) 50 """" """") "" "" (command ""circle"" (list 5 0) 100 """" """")" '  LISP1
    lispCode1 = Range("B2").Value & vbCr & Range("B3").Value
    'lispCode2 = Range("B3").Value
    '  LISP to AutoCAD
    'acadApp.ActiveDocument.SendCommand lispCode2 & vbCr
End Sub
skchui6159
It will show like that
skchui6159
 Autocad Action (Lisp)
Excel cell -B2 Value(command "_circle" (list 5 0) 50 "")
Excel cell -B3 Value(command "_circle" (list 5 0) 70 "")
Ed__Jobe
Why are you trying to use Excel to create AutoCAD entities? Why not just use lisp or VBA?
Ed
