Problem insert table to Autocad from Excel by VBA
malmal02122023
Message 1 of 21
malmal02122023
Could you help me please?
I try to insert the table to AutoCad from Excel but I have a problem with function definition  as shown below
AutoCad2019
Sub GetExcel()
'Excel
Dim wb As excel.workbook
Dim ws As excel.worksheet
Dim text As String
Set wb = GetExcelObject()
Set ws = wb.sheets("CAD")
'CAD
Dim vinsertionpoint As Variant
Dim lnumberofrows As Long
Dim lnumberofcolumns As Long
Dim otable As AcadTable
With ThisDrawing.Utility
vinsertionpoint = .GetPoint(, vbCr & "pick the insertion point: ")
End With
lnumberofrows = 6
lnumberofcolumns = 5
Set otable = ThisDrawing.ModelSpace.AddTable(vinsertionpoint, _
lnumberofrows, lnumberofcolumns, 5, 15)
otable.SetText 0, 0, "Emacro"
'excel -> CAD
text = ws.cells(1, 1)
ThisDrawing.Utility.Prompt (text) + vbNewLine
otable.SetText 1, 0, text
For irow = 1 To lnumberofrow - 1
For icolumn = 0 To lnumberofcolumn - 1
'text = cstr(irow) + "," + cstr(icolumn)
text = ws.cells(irow, icolumn + 1)
otable.SetText irow, icolumn, text
Next
Next
End Sub
Function GetExcelObject() As excel.workbook
Dim path As String
path = "C:\Users\amali\Downloads\TEST TABLE.xlsx"
Dim ret
ret = isworkbookopen(path)
If ret = True Then
Set wb = VBA.GetObject(path)
ThisDrawing.Utility.Prompt ("excel open") + vbNewLine
Else
Set wb = excel.workboks.Open(path)
ThisDrawing.Utility.Prompt ("excel closed") + vbNewLine
Set getexcelobjet = wb
End Function
Function isworkbookopen(filename As String)
Dim ff As slong, errno As Long
On Error Resume Next
ff = FreeFile()
Open filename For Input Lock Read As #ff
Close ff
errno = Err
On Error GoTo 0
Select Case errno
Case 0: isworkbookopen = False
Case 70: isworkbookopen = True
Case Else: Error errno
End Select
End Function
Sub GE()
'excel
Dim rg As excel.range
Dim text As String
Set ws = wb.sheets("Presupuesto")
'cad
End With
Lnumberorows = 5
If Err Then Exit Sub
Set otable = ThisDrawing.ModelSpace.adtable(vinsertionpoint, _
Lnumberogrows, lnumberofcolumns, 5, 50)
This drawing.Utility.Prompt(text) + vbNewLine
otable.SetText 0, 0, "Presupuesto"
For irow = 1 To lnumberofrows
For icolumn = 1 To 5
Set rg = ws.cells(irow, icolumn)
text = rg.text
otable.SetText irow, icolumn - 1, text
Next
Next
End Sub
Thank you for advice
Best regards
Olek
Replies (20)
Message 21 of 21
Ed__Jobe
You can't select the WHOLE sheet. It's thousands of columns wide and thousands of rows deep. You need to select a range for the datalink. Select Option 2 if you've created a named range in xl. You also can use the Print Area, which is the default for Option 2. Select Option 3 if you want to manually specify the range. This option is close to what you are trying to do in code. Remember, the whole point of using a DataLink is so that you can specify the area in xl that you want to work with. If you do this here, you don't need to do it in code.
Ed
How to post your code.
