Add file name as Mtext
abbas.baghernezhad
abbas.baghernezhad
Hi
I want to add file name (or maybe some other information) to my model space like somthing that command "field" does. here is code , it works except the most important thing! How can i access my file name (info variable)?
Sub fn()
Dim pt(0 To 2) As Double
Dim w As Double
Dim text As AcadMText
Dim ent As AcadEntity
Dim info As String
pt(0) = 10: pt(1) = 0: pt(2) = 0
Width = 10
info=?
Set text = ThisDrawing.ModelSpace.AddMText(pt, Width, info)
For Each ent In ThisDrawing.ModelSpace
 If TypeOf ent Is AcadMText Then
Debug.Print ent.TextString
Next
End Sub
norman.yuan
Try this:
Option Explicit
Sub fn()
    Dim w As Double
    Dim info As String
    w = 10
    info = "%<\AcVar Filename \f ""%fn7"">%"
    Set text = ThisDrawing.ModelSpace.AddMText(pt, w, info)
    text.Update
End Sub
Norman Yuan
Drive CAD With Code
abbas.baghernezhad
I did try that. But I was getting syntax error...
some charachter must have been missing.
Thank You.
Ed__Jobe
A syntax error means that you didn't follow the code language properly. When you get that error, it will highlight the problem code. What line got the error?
Ed
How to post your code.
abbas.baghernezhad
 I mistyped some charachters while copy-pasting. Problem is solved .Thank You.
