Populate ListBox from Text File - Without Repeats
I've seen many examples of populating a listbox from a text file, but my text file will have many repeats of the same items, and I'd like to weed these out, and just have a list of available items, with no repeats.
I'm presently working on the code, so I don't have anything to post yet. My present idea is to start an array with the first item from the text file, then compare the next item to the array entry, and if it does not match, then add it to the array. As the array grows, the text item will be compared to each item in the array, discarding any matches and adding any new items.
I'm sure I'll figure it out, but if anyone has something that's already done, I'd appreciate handouts. I'll post whatever I come up with if there are no responses.
Thanks.
I got it. Here's the code if anyone's interested. The first item in the array is left blank, so at the end, I check for a blank entry before populating the list. I use a listbox and a command button on my test form.
Private Sub Command1_Click()
Dim FN As Long
Dim Lister() As String
Dim Inc As Integer
Dim booMatch As Boolean
FN = FreeFile
Open "Textfile.txt" For Input As #FN
Inc = 0
ReDim Preserve Lister(0)
Do While Not EOF(FN)
Line Input #FN, linestring
booMatch = False
For lp = 0 To UBound(Lister)
If Lister(lp) = linestring Then booMatch = True
Next lp
If booMatch = False Then
Inc = Inc + 1
ReDim Preserve Lister(Inc)
Lister(Inc) = linestring
Loop
Close FN
With List1
.Clear
If Lister(lp) <> "" Then .AddItem Lister(lp)
Next lp
.ListIndex = 0
End With
End Sub
