"Key not found" error
03:49 PM
When I run the code below I get this error:
Run-time error '-2145386476 (80200012)':
Key not found
with an "OK" button and a "Help" button. The help button does literally
nothing when clicked and the OK button just makes the dialog go away,
nothing more. Here's the code:
Sub FixLayers()
Dim MyLayers As AcadLayers
Dim myLayer As AcadLayer
Set MyLayers = ThisDrawing.Layers
For Each myLayer In MyLayers
Set myLayer = ThisDrawing.Layers(Name)
With myLayer
Select Case UCase(Name)
Case "S-COCO"
.Name = "S-CONC-COLS"
Case "S-WACO"
.Name = "S-CONC-WALL"
Case "S-DIM"
.Name = "S-ANNO-DIMS"
Case Else
Debug.Print "Old Layer Name Not Found"
End Select
End With
Next
End Sub
matthew g.
"...take my world all apart, take it now, take it now,
and serve the ones that I despise, speak the words I can't deny..."
-- Dan Haseltine
Key not found
Sub FixLayers()
With myLayer
Case "S-COCO"
Case "S-WACO"
Case "S-DIM"
Case Else
End Select
End With
Next
End Sub
matthew g.
-- Dan Haseltine
