Ability to switch screen colors on a button?
Message 1 of 10
I work with my background @ color 253 because I can't see a lot of colors on a black background... but most of my colleagues can't see ANYTHING when they look at my screen because they are so used to the OTB black screen.
So I am wondering if there is a macro/lisp out there that I could use to toggle between the 2 colors when I'm trying to show someone something on my screen.
Thanks in advance!
Replies (9)
Message 2 of 10
Yes, you can write a very simple VBA macro to
toggle the graphic background color. A quick code example:
''Toggle back color between black and
white
Public Sub ToggleModelSpaceBackColor()
    If
ThisDrawing.Application.Preferences.Display.GraphicsWinMOdelBackgrndColor=vbBlack
Then
ThisDrawing.Application.Preferences.Display.GraphicsWinMOdelBackgrndColor=vbWhite
    Else
End Sub
Then you can create toolbar button to run this
macro by a single click.
I
look at my screen because they are so used to the OTB black screen. So I am
Thanks in advance!
Message 3 of 10
If I knew the first thing about VBA, which sadly I don't I could write the required macro.
Anyone want to make my Friday and whip something up?
Thanks Again!
Message 4 of 10
Someone correct me if I'm wrong, but the code above looks like enough to do it as is.
I'm gonna run thru this off the top of my head, so someone please correct any oversights:
Go to the Tools Drop-Down Menu in AutoCAD, select Macro, then VBA Manager, and click the New button, which will create a new code window called Global1, or some other number.
Close that dialog box and hit Alt+F11 to bring up the VBA Editor Interface.
In the Project window (top left) will be ACADProject(Global1) and its sub-item ThisDrawing.
DoubleClick ThisDrawing and a blank page will come up for code input.
Paste the code into this page and save it. Make sure you know where you're saving it, so you can find it in the next step.
In AutoCAD, enter the command APPLOAD. Navigate to where you saved the code, and select it.
Hit Load button to load for now, and/or drag the file into the suitcase to keep it loaded anytime.
Make a button (which I won't go into now) and use this macro:
-vbarun;ToggleModelSpaceBackColor;
Something like that. Customization is fun. Don't be shy - jump in and splash around a little.
Message 5 of 10
OK I got it all added and then created my button, assigned the macro -vbarun;ToggleModelSpaceBackColor;
Now when I hit that button it returns:
Compile Error:
Syntax Error
OK/Help
Hitting OK it brings up the VBA editor and highlights (in yellow) Public Sub ToggleModleSpaceBackColor ()
Thanks for educating the uneducated!
Message 6 of 10
I couldn't tell from your last post if you were able to run it or not, but the word Model in your last post was misspelled. You have Modle. Have you been able to run it?
Message 7 of 10
I just checked and the macro has it spelled right, and to answer your question no I haven't got it to run yet.
Message 8 of 10
I also noticed that the original code has "vbWhi te" (should be "vbWhite") and "vbBla ck" (should be "vbBlack"). Edited by: Frisby on Oct 29, 2008 1:49 PM
Message 9 of 10
Yep that fixed it!
Now... I want to go from Color 252 - Black. I tried substituting '252', 'Color 252 (space & no space)' for White but it then just seemed to toggle Black-Black. What am I missing to be able to switch from a Black background to Color 252?
TIA
Message 10 of 10
I changed my BG color to 252 and then ran the following macro:
Public Sub BGCtest()
Dim nowColor As Variant
nowColor = ThisDrawing.Application.Preferences.Display.GraphicsWinModelBackgrndColor
MsgBox (nowColor)
End Sub
The message box says that the BG color is 8684676, so replaced "vbWhite" with "8684676" and that worked.
