polyline segment length
hari.ramalingam
Message 1 of 9
hari.ramalingam
hi all,
i am new to vba, we have a unique requirement. we have leader (polylines) to label components. we we want the length of one of the segment of polyline to be 6" (as shown in attachment). is it possible?
thanks
Hari
Replies (8)
Message 2 of 9
seabrahenrique
Try this:
Sub ChangeMLeader()
' Declare variables
Dim objMLeader As AcadMLeader
' Get MLeader from the user
ThisDrawing.Utility.GetEntity objMLeader, pt
' Change the landing distance of the MLeader
objMLeader.DoglegLength = 6
' Update the MLeader
objMLeader.Update
End Sub
I guess the .DoglegLenght is the parameter that you find.
Hope can help u.
Message 3 of 9
Ed__Jobe
No need for programming. Define an mleader style with the landing distance set to 6". Then select the leaders and change their style .
Ed
How to post your code.
Message 4 of 9
Smaltsbarger
Create a leader with your parameters using the Multileader Style manager. Command MLEADERSTYLE.
Message 5 of 9
hari.ramalingam
hi @seabrahenrique  thanks,
but our client is using polylines instead of mleader, is there any way we can change the polyline to mleader as it is?
Message 6 of 9
seabrahenrique
Right.
So if i understood correct: You have a polyline itself and want to change the length of a specific segment inside this polyline, correct?
In this case i guess the only way is to reconstruct your poyline changing the X position of one vertice to "grow" the required part of your polyline, you know?
I hope can help!
Message 7 of 9
hari.ramalingam
thanks again for your reply @seabrahenrique
is it possible to construct the polyline via vba code?
thanks
Hari R.
Message 8 of 9
seabrahenrique
Yes, and is pretty simple.
See the code bellow:
Sub MakePolyline()
    ' Declare variables
    Dim objPolyline As AcadPolyline, Coords(8) As Double
    'First Point
    Coords(0) = 0 'X
    Coords(1) = 0 'Y
    Coords(2) = 0 'Z
    'Second Point
    Coords(3) = 6 'X
    Coords(4) = 0 'Y
    Coords(5) = 0 'Z
    'Last Point
    Coords(6) = 20 'X
    Coords(7) = 20 'Y
    Coords(8) = 0 'Z
    ' Create a new Polyline object
    Set objPolyline = ThisDrawing.ModelSpace.AddPolyline(Coords)
End Sub
They do one Polyline similar a your first picture:
You also can "capture" the polylines and they vertices in all your project and try to reconstruct then after making some changes... Is just a suggestion, if i got what your need correctly.
I hope can help.
Message 9 of 9
Ed__Jobe
oooh, slap their hand!  😁 No reason to use polylines as leaders.
Ed
