PlotToDevice
PlotToDevice
PlotToDevice
Is there a way to pause after using PlotToDevice to assure that the process is not interrupted? Because that is the only reason I can think of that would cause this to work...
If Not PlotObject.PlotToDevice Then
Msgbox "No Go!"
End If
But not this.
If Not PlotObject.PlotToDevice ( [A pc3 file I specify] )
Msgbox "No Go!"
end if
Try setting the BACKGROUNDPLOT system variable to 0.
Regards - Nathan
