HelloWorld program.
HelloWorld program.
HelloWorld program.
I have selected Autodesk.AutoCAD.Interop.common as my GAC reference. Why won't this program compile????
' Created by SharpDevelop.
' User: ESepich
' Date: 8/10/2005
' Time: 12:20 PM
' To change this template use Tools | Options | Coding | Edit Standard Headers.
Imports System
Imports System.Runtime.InteropServices
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports acadApp = Autodesk.AutoCAD.ApplicationServices.Application
Public Class HelloWorld
_
Public Sub HelloCommand()
acadApp.DocumentManager.MdiActiveDocument.Editor.WriteMessage( _
vbNewLine & "Hello World!" & vbNewLine)
acadApp.UpdateScreen()
End Sub
End ClassM
ERRORS:
------ Build started: Project: HelloWorld Configuration: Debug ------
Performing main compilation...
C:\Documents and Settings\ESepich\Desktop\HelloWorld\HelloWorld.vb(11) : error BC30466: Namespace or type 'Runtime' for the Imports 'Autodesk.AutoCAD.Runtime' cannot be found.
C:\Documents and Settings\ESepich\Desktop\HelloWorld\HelloWorld.vb(12) : error BC30466: Namespace or type 'ApplicationServices' for the Imports 'Autodesk.AutoCAD.ApplicationServices' cannot be found.
C:\Documents and Settings\ESepich\Desktop\HelloWorld\HelloWorld.vb(14) : error BC30466: Namespace or type 'Application' for the Imports 'Autodesk.AutoCAD.ApplicationServices.Application' cannot be found.
C:\Documents and Settings\ESepich\Desktop\HelloWorld\HelloWorld.vb(16) : error BC30481: 'Class' statement must end with a matching 'End Class'.
C:\Documents and Settings\ESepich\Desktop\HelloWorld\HelloWorld.vb(19) : error BC30451: Name 'acadApp' is not declared.
C:\Documents and Settings\ESepich\Desktop\HelloWorld\HelloWorld.vb(20) : error BC30451: Name 'vbNewLine' is not declared.
C:\Documents and Settings\ESepich\Desktop\HelloWorld\HelloWorld.vb(21) : error BC30451: Name 'acadApp' is not declared.
C:\Documents and Settings\ESepich\Desktop\HelloWorld\HelloWorld.vb(24) : error BC30678: 'End' statement not valid.
End ClassM
Build complete -- 9 errors, 0 warnings
Your "HelloWorld" project uses ObjectARX managed (.NET) API, which is not
installed in GAC. You do no set reference to AutoCAD.Interop dll, which is
for Acad automation.
You need to set reference in your ObjectARX .NET API project to
"Drive:\Acad2005[2006]_installation_folder\acdbmgd.dll" and
"Drive:\Acad2005[2006]_installation_folder\acmgd.dll".
By the way, you'd better to post ObjectARX managed API related message to
"autodesk.autocad.customization.dotnet" group, instead of in VBA group
wrote in message news:4925305@discussion.autodesk.com...
' User: ESepich
' Date: 8/10/2005
' Time: 12:20 PM
Headers.
Imports System
_
End Sub
End ClassM
ERRORS:
End ClassM
