Plot Setting dialog
Plot Setting dialog
tien_nguyenkhanh
Plot Setting dialog
tien_nguyenkhanh
Hi everyone,
I would like to apply the plot setting for multiple AutoCAD files. I have researched in the library and found out that almost needed API for the plot setting as the image attached.
But I still missing some options:
- Page setup
- Shaded viewport options - Quality
- Plot transparency
- Plot stamp on
- Save changes to layout
Thank you
Ed__Jobe
1. Page Setup name - PlotConfiguration.Name, which are stored in the PlotConfigurations collection.
2. Shaded viewport options - Not Exposed in ActiveX
3. Plot Transparency - Not Exposed in ActiveX
4. Plot Stamp On - Not exposed in ActiveX
5. Save changes to layout - This is just code in the dialog that sets the ActivePlotConfiguration with the settings from the PlotConfiguration you are working on. To change the settings of a Layout, you need to edit the Layout properties using the property values from a PlotConfiguration object using the Layout.CopyFrom method.
Ed
How to post your code.
