Ordinate dimensions references WCS instead of UCS when adding ordinate dimensions using VBA
prakashshahA5HG8
prakashshahA5HG8
Although I have new UCS created and activated, when I add an ordinate dimension using VBA it references WCS instead of the UCS. But, When I add the ordinate dimension manually it works well. How can we fix this? I have attached an image below.
Ed__Jobe
All the AddEntity methods work with the WCS. At that time, the Measurement property is set to the value of the defining point, which is in wcs units. The dim object knows what coordinate system it was created in and if you move the origin, the Measurement property is changed, but in the units of the coordinate system in which it was created. I don't see a way to alter this in the ActiveX api.
Ed
How to post your code.
Ed__Jobe
Here's how you can do it in C#.
Ed
