creating a table with several attributes
victorctti
victorctti
Hello again,
I'm developing code for counting, numbering and creating a table for dynamic blocks, but I'm dissolving it and the attached code is working, but the code creates an individual table for each block, there could be a table for all selected blocks where each line represents the block and its values
exemplo for final version:
at the moment:
Public NumNCE As Single
Public TagBl As String
Public NumNDT As String
Public NumNDC As String
Public NumNTE As String
Public PV As String
Public NAME As String
Public CodX As Double
Public CodY As Double
Public CodZ As Double
Public col As Double
Public lin As Double
Public key As Double
Public props() As AcadDynamicBlockReferenceProperty
Sub CONT_BOX_ESGOTO_COM_TAB()
Dim FilterData(0 To 1) As Variant 'cria a variavel filtro data
Dim FilterType(0 To 1) As Integer 'cria a variavel filtro type
Dim FlagTCdAnt As Boolean
Dim ModelSpecObj As AcadModelSpace
Dim NCirc As Integer
Dim NCol As Integer, NLin As Integer
Dim NOrig As Integer
Dim NumLinsTCd As Variant
Dim PtoInsTCd As Variant
Dim PtoLL As Variant, PtoUR As Variant
Dim PtoMR(0 To 2) As Double
Dim TabEnt As AcadTable
Dim TCCdEnt As AcadTable
Dim Verde As AcadAcCmColor
Dim Dad() As String
Dim TagShf As String
Dim LrgShf As Single
Dim PrfShf As Single
Dim dados As String
col = 8
lin = 3
key = 0
LrgShf = 1
PrfShf = 1
FlagOsnap = ThisDrawing.ObjectSnapMode
If FlagOsnap Then
    ThisDrawing.ObjectSnapMode = True
'MENSAGEM DO inputbox
NumNCE = InputBox("Entre o numero inicial para numeração de caixas de esgoto", "Numero de caixas de esgoto")
TagBl = InputBox("Defina o código inicial da tag (3 caracteres)", "Tag do bloco")
For Each SSet In ThisDrawing.SelectionSets
    If SSet.NAME = "CDI" Then
        ThisDrawing.SelectionSets.Item("CDI").Delete ' elemina outro selection set chamado cdi
        Exit For
Next SSet
Set SelCDI = ThisDrawing.SelectionSets.Add("CDI") 'seta um selection set chamado cdi
Set BlkCol = ThisDrawing.Blocks ' setar o bloco a ser modificado
FilterType(0) = 0
FilterData(0) = "Insert" 'tudo que é inserido
FilterType(1) = 8 ' vai precisar acrescentar desenhos 3d
FilterData(1) = "AHD" ' preciso trocar o shf
FimSel = 1 ' chave para entrar no while
Do While FimSel <> 0
    SelCDI.SelectOnScreen FilterType, FilterData ' cria o selection set chamado cdi com um filtro de busca 0,
    'inserido, bloco dinamico, layer AHD
    key = key + 1
    If SelCDI.Count = 1 Then ' se tiver uma seleção entra no if
        Set BlkEnt = SelCDI(0) ' se a caixa de esgoto estiver no selection set
        AtribCol = BlkEnt.GetAttributes 'pega o atributo da caixa de esgotoBlockReference.InsertionPoint
        props = BlkEnt.GetDynamicBlockProperties
        X = BlkEnt.insertionPoint
        NAME = BlkEnt.EffectiveName
        If NAME = "-pvqua" Or NAME = "-pvcir" Then
            col = 9
            NumNTE = AtribCol(4).TextString
        Else
            col = 8
        NumAtribs = UBoundAtributes 'define o valor do atributo
        NumAtribs = UBound(AtribCol) + 1 ' acrescenta o valor ao atributo da caixa de esgoto
        AtribCol(0).TextString = TagBl & NumNCE ' re-escreve o valor do atributo
        NumNDT = AtribCol(1).TextString
        NumNDC = AtribCol(2).TextString
        PV = AtribCol(3).TextString
        CodX = X(0) 'CORDENADA X
        CodY = X(1) 'CORDENADA Y
        CodZ = X(2) 'CORDENADA Z
        'NumNDT = InputBox("Identifique o nivel da tampa", "Nivel da tampa")
        'AtribCol(1).TextString = NumNDT
        'NumNDC = InputBox("Identifique o nivel do fundo", "Nivel do fundo")
        'AtribCol(2).TextString = NumNDC
        Application.Update ' atualiza o desenho
        NumNCE = NumNCE + 1
        SelCDI.Clear ' limpa o selection set
        NumCarTagShf = Len(BlkEnt.NAME)
        TagShf = Right(BlkEnt.NAME, NumCarTagShf) ' - 3)
        Set BlkDef = BlkCol.Item(BlkEnt.NAME)
        NumEntsShf = BlkDef.Count
        PtInsShf = BlkEnt.insertionPoint
        AngTab = BlkEnt.Rotation
        XSFac = BlkEnt.XScaleFactor
        AtribColShf = BlkEnt.GetAttributes
         For NEnt = 0 To NumEntsShf - 1
            Set EntBlkCol = BlkDef.Item(NEnt)
            If EntBlkCol.ObjectName = "AcDbBlockReference" Then
                If Left(EntBlkCol.NAME, 6) = "HD§COL" Then
                    NumColShf = NumColShf + 1
                    AtribColCol = EntBlkCol.GetAttributes
                    For Each AtribCol In AtribColCol
                        Select Case AtribCol.TagString
                        Case "TAG"
                            Dad(NumColShf, 1) = AtribCol.TextString
                        Case "DIA"
                            Dad(NumColShf, 2) = AtribCol.TextString
                        End Select
                    Next AtribCol
        Next NEnt
        HTab = (NumColsShf * 4 + 5) * Esc ' preciso redimencionar tudo isso para o meu objetivo
        DistP1 = Sqr((LrgShf / 2) ^ 2 + PrfShf ^ 2)
        AngP1 = Atn(PrfShf / LrgShf * 2)
        XInsTab = LrgShf / 2 - HTab / 2
        YInsTab = PrfShf * SFac + 10 * Esc
        DistPtTab = Sqr(XInsTab ^ 2 + YInsTab ^ 2)
        AngPtTab = Atn(YInsTab / XInsTab) + Pi
       PtTab = ThisDrawing.Utility.PolarPoint(PtInsShf, AngPtTab + AngTab, DistPtTab)
        PtP1 = ThisDrawing.Utility.PolarPoint(PtInsShf, AngP1 + AngTab, DistP1)
        PtP2 = ThisDrawing.Utility.PolarPoint(PtTab, AngTab, HTab / 2)
        If XSFac = -1 Then
            CorAng = Pi
        Else
            CorAng = 0
        DesTCol PtTab, AngTab + CorAng + Pi / 2, Val(NumColShf), TagShf, Dad
       ' Set LineObj = ThisDrawing.ModelSpace.AddLine(PtP1, PtP2)
        '    LineObj.Layer = "AHD"
    'End If
    'Next BlkEnt
        'ThisDrawing.ModelSpace.AddTable(3, col + 1, 3, 4, 10)
    Else
        FimSel = 0 ' libera do while
Loop
'NumNCE +2 IGUAL NUMERO DE LINHAS
End Sub
Sub DesTCol(PtInsTC As Variant, AngTC, NumCols As Integer, TagShf, Dad() As String)
Dim TColsEnt As AcadTable
Dim DimeA As Single
Dim DimeB As Single
If NAME = "-pvqua" Then
    DimeA = props(1).Value
    DimeB = props(3).Value
ElseIf NAME = "-pvcir" Then
    DimeA = props(0).Value
    DimeB = props(2).Value
Else
    DimeA = props(0).Value + props(2).Value
    DimeB = props(4).Value + props(8).Value
'DimeA = props(0).Value + props(2).Value
'DimeB = props(4).Value + props(8).Value
'AZI = props(10).Value
Set Verd = AcadApplication.GetInterfaceObject("AutoCAD.acCmColor.20") ' talvez trocar as cores
Set Cyan = AcadApplication.GetInterfaceObject("AutoCAD.acCmColor.20")
Verd.ColorIndex = acGreen
Cyan.ColorIndex = acCyan
Set TColsEnt = ThisDrawing.ModelSpace.AddTable(PtInsTC, 3, col, 0.07, 3) 'o 8 é a posição das colunas, NumCols +1 são as linhas
With TColsEnt
.AllowManualHeights = True
'.SetColumnWidth 1, 8
'.SetColumnWidth 2, 8
.MergeCells 0, 0, 0, 0
.SetRowHeight 0, 0.4
.SetCellContentColor 0, 0, Verd
.SetCellTextHeight 0, 0, 0.3
    .SetCellTextHeight 1, 0, 0.12
    .SetCellTextHeight 1, 1, 0.12
    .SetCellTextHeight 1, 2, 0.12
    .SetCellTextHeight 1, 3, 0.12
    .SetCellTextHeight 1, 4, 0.12
    .SetCellTextHeight 1, 5, 0.12
    .SetCellTextHeight 1, 6, 0.12
    .SetCellTextHeight 1, 7, 0.12
    .SetCellTextHeight 1, 8, 0.12
    .SetCellTextHeight 2, 0, 0.13
    .SetCellTextHeight 2, 1, 0.13
    .SetCellTextHeight 2, 2, 0.13
    .SetCellTextHeight 2, 3, 0.13
    .SetCellTextHeight 2, 4, 0.13
    .SetCellTextHeight 2, 5, 0.13
    .SetCellTextHeight 2, 6, 0.13
    .SetCellTextHeight 2, 7, 0.13
    .SetCellTextHeight 2, 8, 0.13
    .SetCellAlignment 0, 0, acMiddleCenter
    .SetCellGridColor 0, 0, AcCellEdgeMask.acLeftMask, Cyan
    .SetCellGridColor 0, 2, AcCellEdgeMask.acRightMask, Cyan
    .SetCellGridColor 0, 0, AcCellEdgeMask.acBottomMask, Verd
    .SetCellGridColor 0, 1, AcCellEdgeMask.acBottomMask, Verd
    .SetCellGridColor 0, 2, AcCellEdgeMask.acBottomMask, Verd
    .SetCellGridColor 0, 3, AcCellEdgeMask.acBottomMask, Verd
    .SetCellGridColor 0, 4, AcCellEdgeMask.acBottomMask, Verd
    .SetCellGridColor 0, 5, AcCellEdgeMask.acBottomMask, Verd
    .SetCellGridColor 0, 6, AcCellEdgeMask.acBottomMask, Verd
    .SetCellGridColor 0, 7, AcCellEdgeMask.acBottomMask, Verd
    .SetCellGridColor 0, 8, AcCellEdgeMask.acBottomMask, Verd
    'For NLin = 1 To NumCols
    'For NCol = 0 To 2
'        .SetCellAlignment NLin, NCol, acMiddleCenter
'        .SetCellTextStyle NLin, NCol, "SIMPLEX"
   ' Next NCol
'Next NLin
    .SetCellGridColor NumCols, 0, AcCellEdgeMask.acBottomMask, Cyan
    .SetCellGridColor NumCols, 1, AcCellEdgeMask.acBottomMask, Cyan
    .SetCellGridColor NumCols, 2, AcCellEdgeMask.acBottomMask, Cyan
    .SetCellGridColor NumCols, 3, AcCellEdgeMask.acBottomMask, Cyan
    .SetCellGridColor NumCols, 4, AcCellEdgeMask.acBottomMask, Cyan
    .SetCellGridColor NumCols, 5, AcCellEdgeMask.acBottomMask, Cyan
    .SetCellGridColor NumCols, 6, AcCellEdgeMask.acBottomMask, Cyan
    .SetCellGridColor NumCols, 7, AcCellEdgeMask.acBottomMask, Cyan
    .SetCellGridColor NumCols, 8, AcCellEdgeMask.acBottomMask, Cyan
    .SetCellTextStyle 0, 0, "SIMPLEX"
    .SetCellTextStyle 1, 0, "SIMPLEX"
    .SetCellTextStyle 1, 1, "SIMPLEX"
    .SetCellTextStyle 1, 2, "SIMPLEX"
    .SetCellTextStyle 1, 3, "SIMPLEX"
    .SetCellTextStyle 1, 4, "SIMPLEX"
    .SetCellTextStyle 1, 5, "SIMPLEX"
    .SetCellTextStyle 1, 6, "SIMPLEX"
    .SetCellTextStyle 1, 7, "SIMPLEX"
    .SetCellTextStyle 1, 8, "SIMPLEX"
    .SetCellTextStyle 2, 0, "SIMPLEX"
    .SetCellTextStyle 2, 1, "SIMPLEX"
    .SetCellTextStyle 2, 2, "SIMPLEX"
    .SetCellTextStyle 2, 3, "SIMPLEX"
    .SetCellTextStyle 2, 4, "SIMPLEX"
    .SetCellTextStyle 2, 5, "SIMPLEX"
    .SetCellTextStyle 2, 6, "SIMPLEX"
    .SetCellTextStyle 2, 7, "SIMPLEX"
    .SetCellTextStyle 2, 8, "SIMPLEX"
    .SetText 0, 0, "TABELA DE DADOS - CAIXA DE ESGOTO" '& TagShf
    .SetText 1, 0, "CAIXA"
    .SetText 1, 1, "NIVEL TAMPA (m)"
    .SetText 1, 2, "NIVEL TETO (m)"
    .SetText 1, 3, "NIVEL FUNDO (m)"
    .SetText 1, 4, "DIMENS A (m)"
    .SetText 1, 5, "DIMENS B (m)"
    .SetText 1, 6, "COORD X (m)"
    .SetText 1, 7, "COORD Y (m)"
    .SetText 1, 8, "AZIMUTE (graus)"
    .SetText 2, 0, TagBl & NumNCE - 1
    .SetText 2, 1, NumNDT
    .SetText 2, 2, NumNDC
    .SetText 2, 3, PV
    .SetText 2, 4, DimeA
    .SetText 2, 5, DimeB
    .SetText 2, 6, CodX
    .SetText 2, 7, CodY
    .SetText 2, 8, NumNTE
    'For NCol = 0 To 2
   ' Next NCol
'Next NLin
    .SetText 2, 3, NumNTE
    .SetText 2, 3, PV
    .SetText 2, 6, CodX
    .SetText 2, 7, CodY
Else
    'For NCol = 0 To 2
   ' Next NCol
'Next NLin
    .SetText 1, 2, "NIVEL FUNDO (m)"
    .SetText 1, 3, "DIMENS A (m)"
    .SetText 1, 4, "DIMENS B (m)"
    .SetText 1, 5, "COORD X (m)"
    .SetText 1, 6, "COORD Y (m)"
    .SetText 1, 7, "AZIMUTE (graus)"
    .SetText 2, 3, DimeA
    .SetText 2, 4, DimeB
    .SetText 2, 5, CodX
    .SetText 2, 6, CodY
    .SetText 2, 7, PV
'   .SetCellTextStyle 0, 0, "SIMPLEX"
'    .SetCellTextStyle 0, 1, "SIMPLEX"
'    .SetCellTextStyle 0, 2, "SIMPLEX"
'    .SetCellTextStyle 0, 3, "SIMPLEX"
'    .SetCellTextStyle 0, 4, "SIMPLEX"
'    .SetCellTextStyle 0, 5, "SIMPLEX"
'    .SetCellTextStyle 0, 6, "SIMPLEX"
'    .SetCellTextStyle 0, 7, "SIMPLEX"
'    .SetText 0, 0, TagBl & NumNCE - 1
'    .SetText 0, 1, NumNDT
'    .SetText 0, 2, NumNDC
'    .SetText 0, 3, DimeA
'    .SetText 0, 4, DimeB
'    .SetText 0, 5, CodX
'    .SetText 0, 6, CodY
'    .SetText 0, 7, PV
'End If
    '.SetText NLin, 0, Dad(NLin, 1) ' 'PRENCHE A COLUNA 1
    '.SetText NLin, 2, Dad(NLin, 2) ''PRENCHE A COLUNA 3
'Next NLin
'.StyleName = "SIMPLEX"
'    .ScaleEntity PtInsTC, 1 * Esc
    .Rotate PtInsTC, AngTC
    .Layer = "AHD"
End With
End Sub
Ed__Jobe
You didn't ask any questions. Did you need help with something or are you just sharing your code?
Ed
How to post your code.
victorctti
Yes, I need help because I can only create one table per selected block and I'm not able to make this code feed the table with more rows with information from other blocks, would you know how?
Ed__Jobe
Can you explain what your goal is? What do you really want to do? Also, rather than setting properties on each and every cell, Create a table style and apply it to the table.
Ed
