Open DWG dialog window from excel
chrisjspower
chrisjspower
Is it possible?
I have got this far:
Open autocad application
Check if app is open
if not - MsgBox
Set the open document to the active document
if that returns "nothing" then
open file dialog box <<< this where I fall over 😞
Sub OpenFileCAD()
    Dim AcadApp As Object
    Dim acadDoc As Object
    Dim acadAppVar As Integer
acadAppVar = 0
 'Check if AutoCAD application is open. If is not opened create a new instance and make it visible.
    On Error Resume Next
        Set AcadApp = GetObject(, "AutoCAD.Application")
If AcadApp Is Nothing Then
        Set AcadApp = CreateObject("AutoCAD.Application")
        AcadApp.Visible = True
End If
    'Check (again) if there is an AutoCAD object.
        MsgBox "Message", vbCritical, "AutoCAD Error"
        Exit Sub
        Else:  acadAppVar = 1 '<<< Used later on
End If
    On Error GoTo 0
    'Check if there is an active drawing.
Set acadDoc = AcadApp.ActiveDocument
On Error GoTo 0
'No active drawing found. Create a new one.
If acadDoc Is Nothing Then
' ¯\_(?)_/¯
'acadApp.Visible = True
End If
End Sub
I have spent most of today and all of yesterday trying to figure this out, I have done many a search so please forgive me if I missed something obvious.
Thanks for you time! 🙂
Ed__Jobe
@chrisjspower wrote:
Sub OpenFileCAD()
acadAppVar = 0
End If
        Exit Sub
End If
    On Error GoTo 0
If AcadApp.Documents.Count > 0 Then
Else
Set acadDoc = AcadApp.Documents.Add("acad.dwt")
End If End If End Sub
Try making the changes in red.
Ed
How to post your code.
Norman_Yuan
There is no direct, built-in way in AutoCAD COM API to show open file dialog, other than using Win32 API's Common Dialogs. Since your code runs from Excel side, you do not have to bother using Win32 API, because Excel VBA provides built-in way to show open/save file dialog with Application.FileDialog.
Go to Excel VBA editor, open "Object Browser" window, locate and select "Application" on left, fine "FileDialog" on the right and select it; then click "?" for help documentation/sample code.
HTH
Norman Yuan
Drive CAD With Code
chrisjspower
I couldn't figure out how to apply either of these suggestions, though I tried and am very grateful for the assistance.
I ended up programming the function to start a new ACAD document,
write to it's command line to open a file there,
and then close the "new" document once the opened document was the application focus.
Works pretty well and with the rest of the function without throwing any errors....yet!
