ObjDbx & Layout Name
pranieriADNKG
pranieriADNKG
Ho to all,
I'm trying to change the layout name trough ObjDbx.
I have a lot of drawings, I'm able to open them by ObjDbx and find object inside, eg blocks and related attributes.
What I'm not able to do is change the layout name, inside the drawing there is only one layout and I want to rename it based upon sheet number, but I got an error if I wrote following syntax
ObjDbx.Layouts(1).Name="01"
but I got an error.
Thank you
norman.yuan
The index of the collections (AcadLayouts, AcadLayers, AcadBlocks...) starts from 0. So, the code should be:
objDbxDoc.Layouts(0).Name="NewName"
Norman Yuan
Drive CAD With Code
pranieriADNKG
Hi Norman, I'll try but reading posts from other guys on same argument seems cannot be be changed by ObjDbx. Could you confirm or the main issue it's related to the item number ?.
Thank you
Ed__Jobe
I think I came across something just the other day, but I don't remember where is was, but it said that the Layout object is read-only when using ObjectDbx.
Ed
How to post your code.
daniel_cadext
I tried with  dbx and I get  'Layout does not eixst for renaming',
a legit Autodesk exception because of the typo? ( I’m kidding : )  )
your only choice appears to be ARX, or .NET. I used python just because its fast for prototyping …
import traceback
import PyRx as Rx
import PyGe as Ge
import PyGi as Gi
import PyDb as Db
import PyAp as Ap
import PyEd as Ed
import AxApp24 as Ax
# fails with 'Layout does not eixst for renaming'
def PyRxCmd_doit2():
    try:
        dbx = Ax.getDbx()
        dbx.Open("e:\\06457Submittal.dwg")
        layout: Ax.IAcadLayout
        for layout in dbx.Layouts:
            if layout.Name == "Model":
                continue
            if layout.Name.startswith('S'):
                print(layout.Name)
                layout.Name = "{} +1".format(layout.Name)
        dbx.SaveAs("e:\\06457SubmittalNew.dwg")
    except Exception as err:
        traceback.print_exception(err)
#works
def renameLayout(db : Db.Database):
    token = Db.LayoutManager.setupForLayouts(db)
    mgr = Db.LayoutManager()
    mgr.renameLayout("S1", "S1 WOOOHOO",db)
    Db.LayoutManager.clearSetupForLayouts(token)
def PyRxCmd_doit():
    try:
        sidedb = Db.Database(False,True)
        sidedb.readDwgFile("e:\\06457Submittal.dwg")
        sidedb.closeInput(True)
        renameLayout(sidedb)
        sidedb.saveAs("e:\\06457SubmittalNew.dwg")
Python for AutoCAD, Python wrappers for ARX https://github.com/CEXT-Dan/PyRx
grobnik
Hi thank you for suggestion,
Wherw I can found more on Autocad and PYTHON ?
I tried your link but seem you have to install before PYTHON.
More suggestions ?
daniel_cadext
There’s a couple of options, you can use win32com & pywin32, this will access AutoCAD’s ActiveX API
There’s pyautoacad on PyPi, this also uses ActiveX, but has some useful wrappers.
Another notable option is to use IronPython and .NET
There’s PyRx, which is the project I’m working on, its Python wrappers around ARX
Has fun stuff like Jigs, Overrules, Palettes etc. caveat, it’s still a work in progress and assumes some cad API knowledge
PyRx, Python for AutoCAD
1, install python 3.10.10
2, install wxPython 4.2.0 using PIP  (used for dialogs and palettes)
3, run the installer that’s on GitHub  See:
https://github.com/CEXT-Dan/PyRx/blob/main/README.txt
https://github.com/CEXT-Dan/PyRx/blob/main/READMEINSTALL.txt
If you need help on these modules, please ask at the swamp as not to annoy the VBA users here
https://www.theswamp.org/index.php?topic=58162.0
