Need help with inserting donut (error too many points)
Message 1 of 13
error :
Too few elements in SafeArray or total number of elements is not a multiple of three.
I would like to 3 pick points and place items there
I need to put a donut or leader with donut and a line to the bubble pointer (Wblock)
1st point; where center of donut.
2nd point; center of bubble pointer (Wblock)
3rd point; end of point of line “nearest” to the edge of the circle (Wblock)
So the line is drawn from the center of the donut to the edge of the circle.
The Wblock is a circle with 2 attributes which is entered by code.
VBA is attached code.
The attached file has the Set donut REMed out.
Replies (12)
Message 2 of 13
No code attached?
Message 3 of 13
Ok, I thougth I did,
Message 4 of 13
where does it crash?
Message 5 of 13
Set Donut = ThisDrawing.ModelSpace.AddLightWeightPolyline(returnPntDonut)
Error:
Too few elements in SafeArray ot total number of elements is not a multiple of three.
Message 6 of 13
The problem is probably in your Polyline Points.
Here is an example of LW Plyline Points:
Dim plineObj As AcadLWPolyline
Dim points(0 To 9) As Double
' Define the 2D polyline points
points(0) = 1: points(1) = 1
points(2) = 1: points(3) = 2
points(4) = 2: points(5) = 2
points(6) = 3: points(7) = 2
points(8) = 4: points(9) = 4
Let me know if that worked for you
Message 7 of 13
The example above is a Ployline with 5 points!!!!
Message 8 of 13
Here'e an example for creating a Donut using the default values for a donut:
Sub DonutTest()
Dim dID As Double
Dim dOD As Double
Dim vPt As Variant
Dim dRadius As Double
Dim dWidth As Double
vPt = ThisDrawing.Utility.GetPoint(, vbCr & "Select point for donut: ")
dID = ThisDrawing.GetVariable("donutid") / 2
dOD = ThisDrawing.GetVariable("donutod") / 2
dRadius = (dID + dOD) / 2#
dWidth = dOD - dID
Dim vPt1 As Variant
Dim vPt2 As Variant
Dim vPts(3) As Double
Dim opoly As AcadLWPolyline
vPt1 = ThisDrawing.Utility.PolarPoint(vPt, 0#, dRadius)
vPt2 = ThisDrawing.Utility.PolarPoint(vPt, 0#, -dRadius)
vPts(0) = vPt1(0)
vPts(1) = vPt1(1)
vPts(2) = vPt2(0)
vPts(3) = vPt2(1)
Set opoly = ThisDrawing.ModelSpace.AddLightWeightPolyline(vPts)
opoly.ConstantWidth = dWidth
opoly.SetBulge 0, 1#
opoly.SetBulge 1, 1#
opoly.Closed = True
End Sub
"dbp428" wrote in message news:6003834@discussion.autodesk.com...
Error:
of three.
Message 9 of 13
Ok; your code makes a donut, my donut needs to be
ID = 0 and OD = .03
I don't understand what this code does.
dWidth = dOD - dID
Is all this required to get the points into something this line can understand? vPts
Message 10 of 13
change your code to this:
Sub DonutTest()
Dim dID As Double
Dim dOD As Double
Dim vPt As Variant
dRadius = 0.0075
dWidth = 0.015
Dim vPt1 As Variant
Dim vPt2 As Variant
vPts(0) = vPt1(0)
vPts(1) = vPt1(1)
vPts(2) = vPt2(0)
vPts(3) = vPt2(1)
opoly.Closed = True
End Sub
-J
Message 11 of 13
No, all that is to determine the Radius & width based on the values saved in
the drawing in the Sysvars DONUTID & DONUTOD. If you kniow what values you
want, replace the portion where I get these variables with your values.
What I did was to take the 2 Diameters divided by 2 to get the Iner & Outer
radii, add them together and divide by 2 to get the Radius of the donut.
(half the average of the 2). For the width of the Pline I then subtracted
the inner from the outer radius.
To get the 2 points required for the AddLightWeightPolyline method, I used
the PolarPoint to get the points on an arc having the determined radius, the
first at 0 degrees from the picked point, the other 180 degrees (determined
by going 0 degrees at the negative radius distance). I then combined the XY
of these two points into a 4 elememt array which is what the the LWPolyline
method needs.
Whew!. Make sense?
"dbp428" wrote in message news:6004392@discussion.autodesk.com...
ID = 0 and OD = .03
dWidth = dOD - dID
understand? vPts
Message 12 of 13
Yes I got it all fixed.
Thank you!!!! 🙂
see attached file
Message 13 of 13
The only thing I would recommend in the future, put all your user input at the start of the code. That way you can isolate and error prove it better.
Just my 2c
-J
