Convert Lisp command to VBA
To get the height of a piece of mtext, I would use the commands:
(setq text_last (entlast))
(setq mtext_height (cdr (assoc 43 (entget text_last))))
Code 43 of mtext is the height of the mtext.
I'm converting a lot of our lisp routines to VBA. How do I access code 43 of mtext using VBA commands?
Use the "Height" property of the text or mtext.
Here is a rough equivalent to your lisp:
Dim oMText As AcadMText
Set oMText = ThisDrawing.ModelSpace.Item(ThisDrawing.ModelSpace.Count - 1)
MsgBox oMText.Height
HTH
Gary
