Multiline Style
Multiline Style
Multiline Style
Does anyone know of a method for programmatically determining what Multiline
style is currently active? If there's a way of doing it, it's escaping me.
Donald F. Sanborn
Examine the CMLSTYLE variable.
___
"dsanborn" wrote in message
news:[email protected]...
Multiline
me.
Do you notice the lines in "*.mln" ? That defined the style of your mlines. It's your alternative to use Frank's great vbXtender.arx .Unfortunely, the method of "loadmlinestyle" seems dont' work well, Frank , Please tell me how? A thousand thanks to you!!
There's a bug in vbxtender's loadmlinestyle. If you look at the arx source
code you will see that the parameters are reversed. Since they are both
strings, you can just reverse the meaning when you call loadmlinestyle.
This is how I'm calling it:
g_objVbXtenderApp.LoadMLineStyle vstrStyleName, m_kstrMLineStyleFile
You'll notice that the documentation requests the file followed by the style
name. Just ignore it!
One other note, I've found that loading an Mline style only works if the
style has never been loaded before. Once you've loaded a style, you can't
change settings and reload the style. You're stuck with it. (Unless I'm
missing something)
Donald F. Sanborn
"spencerlwx" wrote in message
Now I don't know whether I should fix it for fear of breaking existing
code 😉
"That's no ordinary rabbit."
http://www.acadx.com
Visit my site for a chance to win
a free, autographed copy of
Jerry Winters' "AutoCAD Visual Basics"
source
both
loadmlinestyle.
the style
the
can't
(Unless I'm
> missing something)
> Regards,
> Donald F. Sanborn
mlines.
.Unfortunely, the
tell me
I say fix it because it won't break our code if we don't download the fix!
If we do download the fix, we will know what we're getting into, eh!
Donald F. Sanborn
"Frank Oquendo" wrote in message
> code 😉
> source
> both
> loadmlinestyle.
> the style
> the
> can't
> (Unless I'm
> > missing something)
> > Regards,
> > Donald F. Sanborn
> mlines.
> .Unfortunely, the
> tell me
Consider it done.
the fix!
