Open DWG from VB6 in MDI mode
Can anyone help me with opening a drawing using VB6 in AutoCAD2000 in MDI
mode ?
I can open in R14 without a problem, but not in R2000....
Thanks in advance
Dave
acadApp.Documents.Open(,[ReadOnly])
"That's no ordinary rabbit."
http://www.acadx.com
"Dave Wilkinson" wrote in message
news:0A5630B9E0251DD06D567D259C0462DF@in.WebX.maYIadrTaRb...
in MDI
> mode ?
> Thanks in advance
> Dave
Thanks Frank.
One more question though Frank.
How do I check to see if AutoCAD 2000 is already open, and if so open the
drawing in that session ??
Many Thanks
Dave
"Frank Oquendo" wrote in message
news:332EA1DE27B6FB1DA91EFEED5DB51B49@in.WebX.maYIadrTaRb...
> in MDI
> > mode ?
> > Thanks in advance
> > Dave
Dim acadApp As AcadApplication
On Error Resume Next
Set acadApp = GetObject(, "AutoCAD.Application.15")
If Err Then
Err.Clear
Set acadApp = CreateObject("AutoCAD.Application.15")
If Err Then
MessageBox "Could not connect to AutoCAD"
Exit Sub
news:53A83AF5EBA81DBF838E1C1029A55546@in.WebX.maYIadrTaRb...
> Thanks Frank.
open the
> Many Thanks
> Dave
Works a treat Frank.
Thanks Once Again.
news:9C51216D28D9AB0E8F20B4F94CB82853@in.WebX.maYIadrTaRb...
> If Err Then
> Err.Clear
> If Err Then
> Exit Sub
> End If
> End If
> > Thanks Frank.
> open the
> > Many Thanks
> > Dave
if you don't mind, what is the exact syntax for opening the drawing read
only?
is it:
acadApp.Documents.Open (strDrawingName, ReadOnly)
or is ReadOnly a variable that must be declared and set to true or false?
thanks,
chris b.
news:0E40AA50D0C6AD843B0E19445B285FF7@in.WebX.maYIadrTaRb...
> Thanks Once Again.
> > If Err Then
> > Err.Clear
> > If Err Then
> > Exit Sub
> > End If
> > End If
> > > Thanks Frank.
> > open the
> > > Many Thanks
> > > Dave
You can use True or False directly.
Visit my site for a chance to win
a free, autographed copy of
Jerry Winters' "AutoCAD Visual Basics"
"C. Brunner" wrote in message
news:5697E4704AACB20EFCF04C6B746E8943@in.WebX.maYIadrTaRb...
read
> only?
> is it:
false?
> thanks,
> chris b.
