Merge layers
Merge layers
manu.marjanen
Merge layers
manu.marjanen
How to write VBA code?
Merge two layers (layer1, layer2) together into one layer (layer3)?
grobnik
Hi @manu.marjanen could you explain better ? In my opinion you can add a Layer 3 with required properties coming from Layer 1 and/or Layer 2, find the objects on Layer 1 and Layer 2 move on Layer 3, and in case delete layer 1 & 2 if any other objects is needed on such layer.
If I right understand please let me know, I'll try to write a sample on VBA.
Ed__Jobe
Is there a special need to do it with code? Because the LAYMRG command does this.
Ed
How to post your code.
Ed__Jobe
The command is hidden at the bottom of the Layers panel in the Home ribbon tab.
Ed
Ed__Jobe
@manu.marjanen  Did you find an answer that works yet?
Ed
