Macro Error
Macro Error
Macro Error
We have a macro that works on some dwgs but not others. Other macros we use work fine. We did have an update to a dwg that we use as a template, but of course the udate should have been transparent (layout page setup and simple text). What could be the cause?
arcticad
I would check for references.
There may be a program that is missing on one computer and not the other, or they may be different versions.
Step through the code and see where it stops.
(defun botsbuildbots() (botsbuildbots))
My crystal ball rolled off the desk the other
day and broke, so I can't help you.
The problem you vaguely describe can have
thousands of possible causes, most of them
being specific to your code.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
wrote in message news:5420105@discussion.autodesk.com...
Ed__Jobe
Some of the "vague" terms: "works", "doesn't work". If you are not sure how to accurately describe the problem, show your code.
Ed
How to post your code.
What I mean is: We have three macros. Sitting at my station, with two dwgs open, two of the macros work fine in both dwgs. One of the macros works fine in an older dwg, but returns "Execution Error" in the other dwg. The macro is supposed to count the number of block instances, populate a schedule and prompt the user for an insertion point.
Sub PanelSchedule()
' This routine inserts a panel schedule into a 1/4-scale drawing file
' This routine counts the panels in a drawing
Dim ss1 As AcadSelectionSet
Set ss1 = ssAdd("ssName")
Dim codes(0) As Integer
Dim values(0)
Dim straightCount As Integer
Dim leftCount As Integer
Dim rightCount As Integer
Dim doubleCount As Integer
Dim hdrCount As Integer
Dim hdlCount As Integer
codes(0) = 2 '2 is filter number for blocknames
'Initialize counts to zero
straightCount = 0: leftCount = 0: rightCount = 0: doubleCount = 0: hdrCount = 0: hdlCount = 0
'Straights
ss1.Clear
values(0) = "Straight"
ss1.Select acSelectionSetAll, , , codes, values
straightCount = ss1.Count
ss1.Clear
values(0) = "Straight Through Panel"
straightCount = straightCount + ss1.Count
'Lefts
ss1.Clear
values(0) = "Left"
leftCount = ss1.Count
ss1.Clear
values(0) = "Left Turn Panel"
leftCount = leftCount + ss1.Count
'Rights
ss1.Clear
values(0) = "Right"
rightCount = ss1.Count
ss1.Clear
values(0) = "Right Turn Panel"
rightCount = rightCount + ss1.Count
'Full Doubles
ss1.Clear
values(0) = "Double"
doubleCount = ss1.Count
ss1.Clear
values(0) = "Double Turn Panel"
doubleCount = doubleCount + ss1.Count
'HD Lefts
ss1.Clear
values(0) = "Half Double - Left Turn"
hdlCount = ss1.Count
ss1.Clear
values(0) = "HD-L"
hdlCount = hdlCount + ss1.Count
'HD Rights
ss1.Clear
values(0) = "Half Double - Right Panel"
hdrCount = ss1.Count
ss1.Clear
values(0) = "HD-R"
hdrCount = hdrCount + ss1.Count
doubleCount = doubleCount + (IIf((hdlCount > hdrCount), hdlCount, hdrCount))
' Insert the block
Dim pSchedule As AcadBlockReference
Set pSchedule = ThisDrawing.ModelSpace.InsertBlock(ThisDrawing.Utility.GetPoint(, "Insertion point: "), "PanelCntBlk.dwg", 1#, 1#, 1#, 0)
' Get the attributes for the block reference
Dim varAttributes As Variant
varAttributes = pSchedule.GetAttributes
varAttributes(0).TextString = straightCount
varAttributes(1).TextString = leftCount
varAttributes(2).TextString = rightCount
varAttributes(3).TextString = doubleCount
' Move the attribute tags and values into a string to be displayed in a Msgbox
' Dim strAttributes As String
' Dim I As Integer
' For I = LBound(varAttributes) To UBound(varAttributes)
' strAttributes = strAttributes & " Tag: " & varAttributes(I).TagString & _
' " Value: " & varAttributes(I).TextString & " "
' Next
' MsgBox "The attributes for " & pSchedule.Name & " are: " & strAttributes, , "GetAttributes Example"
End Sub
Public Function ssAdd(strName As String) _
As AcadSelectionSet
On Error Resume Next
ThisDrawing.SelectionSets(strName).Delete
Set ssAdd = ThisDrawing.SelectionSets.Add(strName)
End Function
Ed__Jobe
Nothing is jumping out at me, other than you don't have any error handling, hence the "execution error". Put a breakpoint at the first line of code and run the macro in the problem dwg. Then step though the code until it errors. Its probably something like a "type mismatch" error or a variable is not getting set.
Ed
Thank you.
