VLA to VBA
VLA to VBA
VLA to VBA
Could someone please point me to the VBA analogues to the Visual Lisp expressions:
(setq XDAT (ssget "X" (list (cons 2 "XFILEDATA"))))
and
(setq XDAT (vlax-ldata-get (ssname XDAT 0) "XFILES" "Key Not found"))
Dim oSS as AcadSeelctionSet
Set oSS = ThisDrawing.SelectionSets.Add("MySS")
Dim iCode(0) as Integer
Dim vData(0) as Variant
icode(0) = 0: vData(0) = "XFILEDATA"
oSS.Select acSelectionSetAll,,,iCode, vData
Note there is is no way (that I'm aware of) to access ldata in VBA. This is
one reason many people have advised not to use ldata.
HTH,
Jeff
wrote in message news:5419878@discussion.autodesk.com...
expressions:
and
Have you walked into the LData snare that Autodesk
has laid ?
My advice is that you get rid of LData entirely,
and use xdictionaries/xrecords. If you don't
you will probably regret it sooner rather than
later.
In VBA or ActiveX, you can store data in xrecords,
but not in as LISP-friendly way as LData.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
and
Thanks for everyones input and there would be one way to access LData in VBA which would be to use the command function to pass the lisp code and write the output to a USER variable, yeah a kludge I know but still...where there's a will.
I'll most probably convert it over to XData.
Thanks again.
