02:33 PM
I have three subroutines in my macro (code below):
- myDraw to draw a line
- myOff to hide the line's layer
- myOn to show the line's layer
When I'm in AutoCAD and I call myDraw using -VBARUN, the line is drawn. When I then call myOff, I get a Lock Violation runtime error. When I click End on the popup, I can use myOff and myOn without problems. When I delete the line and re-call myDraw, I get the Lock Violation again.
The error does not occur when I run the subroutines from within the editor using "Run (F5)".
I am using AutoCAD 2020 on Windows 10
Code:
Public Sub myDraw()
Dim pLine As AcadPolyline
Dim LinePoints(0 To 5) As Double
LinePoints(0) = -100
LinePoints(1) = 100
LinePoints(2) = 0
LinePoints(3) = 0
LinePoints(4) = 0
LinePoints(5) = 0
Set pLine = ThisDrawing.ModelSpace.AddPolyline(LinePoints)
pLine.Layer = "0"
End Sub
Public Sub myOn()
ThisDrawing.Layers("0").LayerOn = True
End Sub
Public Sub myOff()
ThisDrawing.Layers("0").LayerOn = False
End Sub
