Lock Violation when hiding layer
I have three subroutines in my macro (code below):
- myDraw to draw a line
- myOff to hide the line's layer
- myOn to show the line's layer
When I'm in AutoCAD and I call myDraw  using -VBARUN, the line is drawn. When I then call myOff, I get a Lock Violation runtime error. When I click End on the popup, I can use myOff and myOn without problems. When I delete the line and re-call myDraw, I get the Lock Violation again.
The error does not occur when I run the subroutines from within the editor using "Run (F5)".
I am using AutoCAD 2020 on Windows 10
Code:
Public Sub myDraw()
  Dim pLine As AcadPolyline
  Dim LinePoints(0 To 5) As Double
  LinePoints(0) = -100
  LinePoints(1) = 100
  LinePoints(2) = 0
  LinePoints(3) = 0
  LinePoints(4) = 0
  LinePoints(5) = 0
  Set pLine = ThisDrawing.ModelSpace.AddPolyline(LinePoints)
  pLine.Layer = "0"
End Sub
Public Sub myOn()
  ThisDrawing.Layers("0").LayerOn = True
End Sub
Public Sub myOff()
  ThisDrawing.Layers("0").LayerOn = False
End Sub
Ed__Jobe
Put the line on a layer other than "0". That layer is a special layer reserved for use by AutoCAD. Never lock that layer or turn it off. The same is true for "Defpoints". Its best if you ignore those layers and do not use them. The exception is when you are creating blocks. You can put entities on layer 0 if you want them to take on the layer properties of the layer that the block is inserted on.
Ed
How to post your code.
Thanks for your reply, Ed
I created a new layer called myLayer and changed the macro to use "myLayer" instead of "0". However, I get the same behaviour with the Lock Violation error...
Any other idea?
Frank
Ed__Jobe
Is the layer the current layer when you try to turn it off? You need to make some other layer active before you turn it off. I tried your code and I don't get an error.
Also, you need to add a regen to the on/off subs.
ThisDrawing.Regen acAllViewports
Ed
Amazing, thank you very much Ed
Adding ThisDrawing.Regen acAllViewports above the line that threw the error resolved the issue. I had it occur in multiple subroutines and it resolved it in every case!
