ListView Control - prevent change to column widths
mdhutchinson
Advisor Advisor
Message 1 of 38
mdhutchinson
Other than not displaying them, is there a way to prevent the user from changing the column widths when in 'Report' mode?
Replies (37)
Message 21 of 38
i checked his solution and it does not work. would have been nice if you had
done the same.
"Kerry Brown" wrote in message
news:5436457@discussion.autodesk.com...
heh, bob, Just make sure you pay homage to Galen Nickerson the author of
that ...
http://www.vbcodemagician.dk/tips/cctrls_lvpreventresize.htm
"Bob" wrote in message
news:5436391@discussion.autodesk.com...
here is your second installment. enjoy!
Public Sub Hook()
'establish hook to capture messages to this window
lpPrevWndProc = SetWindowLong(gHW, GWL_WNDPROC, AddressOf WindowProc)
End Sub
Public Sub Unhook()
Dim temp As Long
'reset the message handler for this window
temp = SetWindowLong(gHW, GWL_WNDPROC, lpPrevWndProc)
End Sub
Public Function WindowProc(ByVal hwnd As Long, ByVal uMsg As Long, _
ByVal wParam As Long, ByVal lParam As Long) As Long
Dim nmh As NMHDR
Dim nmhd As NMHEADER
Select Case uMsg
Case WM_NOTIFY
'fill the NMHDR struct from the lParam pointer.
'(for any WM_NOTIFY msg, lParam always points to a struct
'which is either the NMHDR struct, or whose 1st member is the
'NMHDR struct)
Call MoveMemory(nmh, ByVal lParam, Len(nmh))
'could combine HDN_BEGINTRACK
'and HDN_DIVIDERDBLCLICK into one
'(i.e.,Case HDN_BEGINTRACK, HDN_DIVIDERDBLCLICK:)
Select Case nmh.code
Case HDN_BEGINTRACK
'User began dragging a divider
Call MoveMemory(nmhd, ByVal lParam, Len(nmhd))
Select Case nmhd.iItem
'Select Case ListView ColumnHeader Index you want to prevent
tracking.
'Note API is 0 based unlike ColumnHeaders collection which is 1
based.
Case 0
'ListView ColumnHeader Index 1 prevent tracking
WindowProc = 1
Exit Function
Case 1
'ListView ColumnHeader Index 2 prevent tracking
WindowProc = 1
Exit Function
Case Else
'other ColumnHeaders allow resizing
End Select
Case HDN_DIVIDERDBLCLICK
'user double clicked the divider area
'you want to prevent resizing if the user double clicks on a
Column separator
based
Case 0
'prevent resizing if the user double clicks on a Column
separator
WindowProc = 1
Exit Function
Case 1
separator
WindowProc = 1
Exit Function
Case Else
End Select
End Select
End Select
'Pass message on to the original window message handler
WindowProc = CallWindowProc(lpPrevWndProc, hwnd, uMsg, wParam, lParam)
End Function
"Tony Tanzillo" wrote in message
news:5435599@discussion.autodesk.com...
Bobo....
Any idiot can copy commonly-used WinAPI
function import declarations that can be found
in thousands of places on the net and in books,
and paste them into a post here.
So, who do you think you're fooling?
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
news:5435528@discussion.autodesk.com...
yeah, i figured you didn't know. so i'll start educating you. here is your
first installment.
Message 22 of 38
hardly, i dispelled the rumor that tony knows all ...
about the only thing he really knows well is how to spew his vial at
unsuspecting users on this group and criticize their attempts at getting
their work done! most of the people using this group are here for answers
not his condescending attitude about how they don't know anything.
he said, "without using the Windows API and
subclassing the control to handle the notifications
that are fired when it happens."
maybe i'm wrong, but so far i haven't seen his answer to the contrary.
Bob
"Allen Johnson" wrote in message
news:5436494@discussion.autodesk.com...
Aw, you take all of his fun away!
Message 23 of 38
Instead of
ListView1.SmallImages = ilsSmall
it should be
ListView1.SmallIcons = ilsSmall
ListView1.View = lvwReport
in the Form_Load event and it works fine.
Message 24 of 38
Yeah, but I thought his response had no vitriolic content in it this time.
BTW, your method uses subclassing as well.
Message 25 of 38
thanks for pointing that out, i didn't bother looking into it ...
news:5436549@discussion.autodesk.com...
Instead of
it should be
Message 26 of 38
since i never said it wouldn't, what is your point?
news:5436534@discussion.autodesk.com...
Message 27 of 38
since there are at least a couple dozen different variations of the exacg
same code available, who do I really honor [other than tony of course]?
galen nickerson, dan apleman, randall wrath, joe sutfin, etc.
and whoever else has posted or otherwise seen this code to the world, thank
you.
frankly i don't remember exactly where i got my version i've had it my
library for years.
that ...
Public Sub Hook()
End Sub
Public Sub Unhook()
Dim temp As Long
End Sub
Dim nmh As NMHDR
Select Case uMsg
Case WM_NOTIFY
'NMHDR struct)
Case HDN_BEGINTRACK
tracking.
based.
Case 0
WindowProc = 1
Exit Function
Case 1
WindowProc = 1
Exit Function
Case Else
End Select
Column separator
based
Case 0
separator
WindowProc = 1
Exit Function
Case 1
separator
WindowProc = 1
Exit Function
Case Else
End Select
End Select
End Select
End Function
Bobo....
first installment.
Message 28 of 38
The solution you found is exactly what Tony said was the only way to do it. So all you have done is prove his point and made an even bigger fool of yourself.
Regards - Nathan
Message 29 of 38
no, he said it could be done without using the windows api or subclassing
and i'm saying that it can't.
wrote in message news:5436885@discussion.autodesk.com...
yourself.
Regards - Nathan
Message 30 of 38
So this whole tirade is because you misunderstood him.
Regards - Nathan
Message 31 of 38
i went back and re-read his original post and perhaps i did misread it.
tony, i apologize for exploding on you with back and forth posts.
Bob
wrote in message news:5436956@discussion.autodesk.com...
Regards - Nathan
Message 32 of 38
Stop posting code that is not yours; which
you did not write; which could not write; which
you do not have a clue about or understand;
and for which you are not crediting the original
source or author.
You're violating the forum rules; infringing on the
intellectual property rights of the original author;
and most importantly; You are fooling no one here,
Bobo.
"Bob" wrote in message news:5436391@discussion.autodesk.com...
Public Sub Hook()
End Sub
Public Sub Unhook()
Dim temp As Long
End Sub
Dim nmh As NMHDR
Select Case uMsg
Case WM_NOTIFY
'NMHDR struct)
Case HDN_BEGINTRACK
tracking.
based.
Case 0
WindowProc = 1
Exit Function
Case 1
WindowProc = 1
Exit Function
Case Else
End Select
Column separator
based
Case 0
separator
WindowProc = 1
Exit Function
Case 1
separator
WindowProc = 1
Exit Function
Case Else
End Select
End Select
End Select
End Function
Bobo....
first installment.
Message 33 of 38
yeah, yeah - you never give it a rest do you? what you meant to say was you
don't know what it does or how to write it. but since you don't know basic
then why would anyone be surprised?
that code has been written and re-written so many times and all the same
way, it's pathetic [much like you]. and unlike you, i'm not trying to fool
anyone ...
for the last time, moron, it's Bob - you're the bobo ...
news:5437737@discussion.autodesk.com...
source or author.
Bobo.
Public Sub Hook()
End Sub
Public Sub Unhook()
Dim temp As Long
End Sub
Dim nmh As NMHDR
Select Case uMsg
Case WM_NOTIFY
'NMHDR struct)
Case HDN_BEGINTRACK
tracking.
based.
Case 0
WindowProc = 1
Exit Function
Case 1
WindowProc = 1
Exit Function
Case Else
End Select
Column separator
based
Case 0
separator
WindowProc = 1
Exit Function
Case 1
separator
WindowProc = 1
Exit Function
Case Else
End Select
End Select
End Select
End Function
Bobo....
first installment.
Message 34 of 38
here is your final installment tony. i hope you have learned something ...
Private Sub Form_Load()
With ListView1
'start listview in upper left-hand corner
.Move 0, 0, ScaleWidth, ScaleHeight
'change the view style to report
.View = lvwReport
'add some columns to demonstrate
.ColumnHeaders.Add , , "Column1"
.ColumnHeaders.Add , , "Column2"
.ColumnHeaders.Add , , "Column3"
.ColumnHeaders.Add , , "Column4"
'store listview handle
gHW = .hwnd
End With
Hook
End Sub
Private Sub Form_Unload(Cancel As Integer)
Unhook
End Sub
oh, one final note ... thanks to everyone who has ever posted the code
contained in these lessons. although it has been written and re-written by
everyone and his first cousin i give each and everyoe of you credit [except
for tony].
Bob
source or author.
Bobo.
Public Sub Hook()
End Sub
Public Sub Unhook()
Dim temp As Long
End Sub
Dim nmh As NMHDR
Select Case uMsg
Case WM_NOTIFY
'NMHDR struct)
Case HDN_BEGINTRACK
tracking.
based.
Case 0
WindowProc = 1
Exit Function
Case 1
WindowProc = 1
Exit Function
Case Else
End Select
Column separator
based
Case 0
separator
WindowProc = 1
Exit Function
Case 1
separator
WindowProc = 1
Exit Function
Case Else
End Select
End Select
End Select
End Function
Bobo....
first installment.
Message 35 of 38
what a vile little attitude.
news:5437927@discussion.autodesk.com...
With ListView1
.View = lvwReport
gHW = .hwnd
End With
Hook
End Sub
Unhook
End Sub
for tony].
Bob
source or author.
Bobo.
Public Sub Hook()
End Sub
Public Sub Unhook()
Dim temp As Long
End Sub
Dim nmh As NMHDR
Select Case uMsg
Case WM_NOTIFY
'NMHDR struct)
Case HDN_BEGINTRACK
tracking.
based.
Case 0
WindowProc = 1
Exit Function
Case 1
WindowProc = 1
Exit Function
Case Else
End Select
Column separator
based
Case 0
separator
WindowProc = 1
Exit Function
Case 1
separator
WindowProc = 1
Exit Function
Case Else
End Select
End Select
End Select
End Function
Bobo....
first installment.
Message 36 of 38
yeah tony will appreciate you more if act just like him ...
news:5437928@discussion.autodesk.com...
With ListView1
.View = lvwReport
gHW = .hwnd
End With
Hook
End Sub
Unhook
End Sub
for tony].
Bob
source or author.
Bobo.
Public Sub Hook()
End Sub
Public Sub Unhook()
Dim temp As Long
End Sub
Dim nmh As NMHDR
Select Case uMsg
Case WM_NOTIFY
'NMHDR struct)
Case HDN_BEGINTRACK
tracking.
based.
Case 0
WindowProc = 1
Exit Function
Case 1
WindowProc = 1
Exit Function
Case Else
End Select
Column separator
based
Case 0
separator
WindowProc = 1
Exit Function
Case 1
separator
WindowProc = 1
Exit Function
Case Else
End Select
End Select
End Select
End Function
Bobo....
first installment.
Message 37 of 38
>> windows api or subclassing and i'm saying that it can't.
Bobo....
Not only are you incompetent with regards to
programming, you can't read either.
You couldn't be more wrong, Bobo...
I said that the only way to do it was with the
Windows API and subclassing.
And yes, thanks for posting the plagurized code
you didn't and couldn't write yourself, to prove
my point.
Message 38 of 38
An tony o ...
then read this ...
you are such a dumb a$$ ... you make assumptions you have no idea about. i
never said that i wrote the code idiot, i only posted it for your ignorant
and arrogant a$$ ... so now who can't read?
if you had half the brains you think you have, you still would have nothing.
chances are you don't even know how to use it inside a vb app!!!
Bob
news:5438054@discussion.autodesk.com...
Bobo....
my point.
