ListView Control - prevent change to column widths
mdhutchinson
Advisor Advisor
Message 1 of 38
mdhutchinson
Other than not displaying them, is there a way to prevent the user from changing the column widths when in 'Report' mode?
Replies (37)
Message 2 of 38
since there is no resize event for a listbox you will probably have to
resource to the windows api for this.
wrote in message news:5434383@discussion.autodesk.com...
Message 3 of 38
mdhutchinson
sorry... this is the Microsoft ListView Control version 6.0
Message 4 of 38
Not easily, and without using the Windows API and
subclassing the control to handle the notifications
that are fired when it happens.
My guess is that it is not easy because there are not
too many legitimate reasons why a user should not
be able to resize columns.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
Message 5 of 38
mdhutchinson
agreed!!!
I was able to get this control to work well... thus far...
resizing the column is what I want... after I got some test data into the list I can clearly see why I want to resize the columns.
Message 6 of 38
i would guess that the reason your answer is wrong is because you don't
know. its not doable without the windows api. or is it? please let us know!
"Tony Tanzillo" wrote in message
news:5434497@discussion.autodesk.com...
Message 7 of 38
Bobo... My answer is not wrong...
Hope you don't have to depend too much
on your 'guessing'.
"Bob" wrote in message news:5434541@discussion.autodesk.com...
Message 8 of 38
then by all means let's see the real answer mr. genius!
news:5435110@discussion.autodesk.com...
on your 'guessing'.
Message 9 of 38
Provoking someone to educate you through
insults, doesn't work with me, Bobo.
Message 10 of 38
yeah, i figured you didn't know. so i'll start educating you. here is your
first installment.
Public Const WM_NOTIFY = &H4E
Public Const GWL_WNDPROC = -4
Public lpPrevWndProc As Long
Public gHW As Long
Public Declare Function CallWindowProc Lib "user32" Alias _
"CallWindowProcA" (ByVal lpPrevWndFunc As Long, _
ByVal hwnd As Long, ByVal Msg As Long, ByVal wParam As Long, _
ByVal lParam As Long) As Long
Public Declare Function SetWindowLong Lib "user32" Alias _
"SetWindowLongA" (ByVal hwnd As Long, ByVal nIndex As Long, _
ByVal dwNewLong As Long) As Long
Public Declare Sub MoveMemory Lib "kernel32" Alias "RtlMoveMemory" _
(pDest As Any, pSource As Any, ByVal dwLength As Long)
'ListView notifications
Public Enum HD_Notifications
HDN_FIRST = -300&
HDN_LAST = -399&
HDN_GETDISPINFO = (HDN_FIRST - 9)
HDN_BEGINDRAG = (HDN_FIRST - 10) 'Drag operation has begun
HDN_ENDDRAG = (HDN_FIRST - 11) 'Drag operation has ended
HDN_ITEMCLICK = (HDN_FIRST - 2) 'User clicked the control
HDN_ITEMDBLCLICK = (HDN_FIRST - 3) 'User double-clicked the control
HDN_DIVIDERDBLCLICK = (HDN_FIRST - 5) 'User double clicked the divider
area
HDN_ITEMCHANGING = (HDN_FIRST - 0) 'An item is changing
HDN_ITEMCHANGED = (HDN_FIRST - 1) 'An item has changed
HDN_BEGINTRACK = (HDN_FIRST - 6) 'User began dragging a divider
HDN_ENDTRACK = (HDN_FIRST - 7) 'User finished dragging a divider
HDN_TRACK = (HDN_FIRST - 8) 'User is dragging a divider
NM_FIRST = -0& ' (0U- 0U)
NM_CUSTOMDRAW = (NM_FIRST - 12) 'Custom draw request notification
NM_RCLICK = (NM_FIRST - 5) 'User clicked right mouse button in
control
NM_RELEASEDCAPTURE = (NM_FIRST - 16) 'Control is releasing mouse
capture
End Enum
when i think you have had enough time to digest this bit of code i'll post
your next installment.
btw, it's bob. learn it ... Tony!
news:5435562@discussion.autodesk.com...
Message 11 of 38
hutch, do any of these do the job for you :
http://www.google.com/search?sourceid=navclient&ie=UTF-8&rls=GGLG,GGLG:2006-24,GGLG:en&q=Prevent+ColumnHeader+sizing
I'm not a prolific VB'er but it seeems that the first 2 may suit your
situation.
regards
kwb
Message 12 of 38
Bobo....
Any idiot can copy commonly-used WinAPI
function import declarations that can be found
in thousands of places on the net and in books,
and paste them into a post here.
So, who do you think you're fooling?
"Bob" wrote in message news:5435528@discussion.autodesk.com...
first installment.
Message 13 of 38
obviously you, moron. study the code, the next installment will come soon.
unless you have a "brilliant" answer, you have nothing!
Bob
news:5435599@discussion.autodesk.com...
Bobo....
first installment.
Message 14 of 38
What does that do?
Regards - Nathan
Message 15 of 38
Obviously this isn't finished yet. Let's see what installment number two will bring.
I'm kind of enjoying what has become the measure of comtempt in this group. Glad to see it hasn't changed in the last decade.
Good luck,
Bob Coward
Message 16 of 38
It is funny that he bagged Tony for saying it can only being done using the WinAPI and subclassing and then posts WinAPI Declarations which on there own means absolutely nothing. I don't hold any hope of a second installment but if it does come it won't be the simple solution he implied there was.
Regards - Nathan
Message 17 of 38
the first installment wasn't complete so it did pretty much nothing.
however, i have posted the second installment. it too is not the complete
solution which will come later.
btw, i never implied the solution would be easy. i think that if you read
tony's posts you might get that impression, but not mine.
wrote in message news:5436237@discussion.autodesk.com...
Regards - Nathan
Message 18 of 38
here is your second installment. enjoy!
Public Sub Hook()
'establish hook to capture messages to this window
lpPrevWndProc = SetWindowLong(gHW, GWL_WNDPROC, AddressOf WindowProc)
End Sub
Public Sub Unhook()
Dim temp As Long
'reset the message handler for this window
temp = SetWindowLong(gHW, GWL_WNDPROC, lpPrevWndProc)
End Sub
Public Function WindowProc(ByVal hwnd As Long, ByVal uMsg As Long, _
ByVal wParam As Long, ByVal lParam As Long) As Long
Dim nmh As NMHDR
Dim nmhd As NMHEADER
Select Case uMsg
Case WM_NOTIFY
'fill the NMHDR struct from the lParam pointer.
'(for any WM_NOTIFY msg, lParam always points to a struct
'which is either the NMHDR struct, or whose 1st member is the
'NMHDR struct)
Call MoveMemory(nmh, ByVal lParam, Len(nmh))
'could combine HDN_BEGINTRACK
'and HDN_DIVIDERDBLCLICK into one
'(i.e.,Case HDN_BEGINTRACK, HDN_DIVIDERDBLCLICK:)
Select Case nmh.code
Case HDN_BEGINTRACK
Call MoveMemory(nmhd, ByVal lParam, Len(nmhd))
Select Case nmhd.iItem
'Select Case ListView ColumnHeader Index you want to prevent
tracking.
'Note API is 0 based unlike ColumnHeaders collection which is 1
based.
Case 0
'ListView ColumnHeader Index 1 prevent tracking
WindowProc = 1
Exit Function
Case 1
'ListView ColumnHeader Index 2 prevent tracking
WindowProc = 1
Exit Function
Case Else
'other ColumnHeaders allow resizing
End Select
Case HDN_DIVIDERDBLCLICK
'user double clicked the divider area
'you want to prevent resizing if the user double clicks on a
Column separator
based
Case 0
'prevent resizing if the user double clicks on a Column
separator
WindowProc = 1
Exit Function
Case 1
separator
WindowProc = 1
Exit Function
Case Else
End Select
End Select
End Select
'Pass message on to the original window message handler
WindowProc = CallWindowProc(lpPrevWndProc, hwnd, uMsg, wParam, lParam)
End Function
Bobo....
first installment.
Message 19 of 38
heh, bob, Just make sure you pay homage to Galen Nickerson the author of
that ...
http://www.vbcodemagician.dk/tips/cctrls_lvpreventresize.htm
news:5436391@discussion.autodesk.com...
Public Sub Hook()
End Sub
Public Sub Unhook()
Dim temp As Long
End Sub
Dim nmh As NMHDR
Select Case uMsg
Case WM_NOTIFY
'NMHDR struct)
Case HDN_BEGINTRACK
tracking.
based.
Case 0
WindowProc = 1
Exit Function
Case 1
WindowProc = 1
Exit Function
Case Else
End Select
Column separator
based
Case 0
separator
WindowProc = 1
Exit Function
Case 1
separator
WindowProc = 1
Exit Function
Case Else
End Select
End Select
End Select
End Function
Bobo....
first installment.
Message 20 of 38
Aw, you take all of his fun away!
