List and select specific layers from COM+ interface
Advanced Software processes DWG files in the background, for example as part of a purchase order or production order. The library we build uses the com+ interface. We would like to know how to list layers and select or deselect specific ones so the output created from the dwg file reflects only the information available on the selected layers. Interactive windows need to be suppressed due to the automated process. Autocad version is Mechanical 2016. Does anyone have experience and helpful information? Kind regards, Annette Steup Advanced Software GmbH annette.steup@advanced-software.de or peter.fruehwein@advanced-software.de www.advanced-software.de
Alfred.NESWADBA
most VBA samples for AutoCAD show how to access AutoCAD drawings through COM.
So look to that documentation and samples >>>click<<<
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Dear Mr Neswabda, We are in general familiar in how build the project as we have done that for quite a number of years. What we are looking for is the syntax to add some new features to the existing library. These features are list active layers in dwg preferably in model space select specific ones deselct specitic ones save or export as pdf For these features we are looking for the correct commands available in com+ interface. Can you help with this? Kind regards, Annette Steup Advanced Software GmbH pfruehwein@advanced-software.de
Alfred.NESWADBA
About creating layers >>>click<<<
Layers exist in the complete drawing-database, they are not specific to a modelspace.
>> These features are list active layers in dwg [...] select specific ones deselct specitic ones
Layers can't be selected (at least not what I see as "user selects an object"), they are part of the definition of a drawing.
You might select objects that have the property ".Layer" set to a value you are looking for.
>> export as pdf
Find the plot functionality >>>here<<<, use the device "DWG to PDF.pc3".
HTH, - alfred -
Alfred NESWADBA
Dear Mr Neswadba, Thanks for coming back with more information. We finally found the one help button in Autocad Mech 2016 that has all the information needed for programmers. So we were able to implement the needed methods. Thank you anyway for the trouble you took. Kind regards, Annette Steup Advanced Software GmbH pfruehwein@advanced-software.de
