lisp to get area and perimeter
S_S_SS
S_S_SS
hi every one
i want a lisp to get area and perimeter and put it inside the objects and make it in meter unit and scale text to 1000 to be clearly displayed
like that image to clearly explain what i want
thanks in advance
Ed__Jobe
First, this is not the LISP forum.
You don't really need to program this. You can just use fields. First, create a text style with the properties you want. Then place an MTEXT at the center and insert a field. In the field dialog, select (1) Object, (2) select the object and then (3) the property to display. Repeat for the other property.
If you want to use VBA, I dealt with this issue a while back.
Ed
How to post your code.
S_S_SS
thanks sir ...
i know the field but i have many polyline and polyline change from drawing to another
i can use list command and get what i want
dut i want to get a lisp to reduce my effort about that
thanks very much for your help
