Insert 0.00 instead of 0,00 as numberformat
stefanveurink68AXD
stefanveurink68AXD
Like title says:
if have format FM = 0.00
However, when inserting text with ThisDrawing.ModelSpace.AddText((Number  FM), Ep, T18) it still gives me: 0,00
instead of the wanted 0.00.
Most be a culture problem, but seems like I can't set this with Vba? I don't want use text replace (cause also possible to insert 1,234.56 instead of 1234.56
Is this solvable?
Thanks!
Ed__Jobe
Is the Number function you show one that you created?
You might try using the VBA FormatNumber function. In the VBAIDE, go to Help and look up the function. It has a GroupDigits argument that allows you to turn off the use of the regional settings.
FormatNumber (FM, 2, vbFalse, vbFalse, vbFalse)
Ed
How to post your code.
stefanveurink68AXD
to come back on this, I tried it but still isn't working. And yes, I see the groupdigits in the objectbrowser. Negative number are changed when I do this, but doesn't matter if i use VbFalse or VbTrue, it always still puts in a comma (,) instead of a dot (.). with all 3 vbFalse and with all 3 with VbTrue.
Ed__Jobe
In your first post, you mentioned "FM = 0.00". What type of object is FM? How is it stored?
Ed
