Message 1 of 8
Hello to all,
I come to you because I can't execute the _join command in VBA.
My macro allows to overlay a symbol that is implanted in a line, retrieve the coordinates of the lines that are around the symbol and join the lines. Here is my code:
Sub Supp_Sur_Ligne()
'Déclaration des variables locales---------------------------------------------------------------------------------------
Dim Entite As AcadEntity
Dim Selection_Symbole As AcadSelectionSet
Dim Block As AcadBlockReference
Dim L1 As AcadLine
Dim L2 As AcadLine
Dim Selection_Ligne1 As AcadSelectionSet
Dim Selection_Ligne2 As AcadSelectionSet
Dim Coordonnees_Ligne_1(0 To 2) As Double
Dim Coordonnees_Ligne_2(0 To 2) As Double
'Fin Déclaration des variables locales-----------------------------------------------------------------------------------
'Sélection du symbole à supprimmer
ThisDrawing.SetVariable "SNAPMODE", 0
On Error Resume Next
If Not IsNull(ThisDrawing.SelectionSets.Item("ss1")) Then
Set Selection_Symbole = ThisDrawing.SelectionSets.Item("ss1")
Selection_Symbole.Delete
Set Selection_Symbole = ThisDrawing.SelectionSets.Add("ss1")
Selection_Symbole.SelectOnScreen
ThisDrawing.SetVariable "SNAPMODE", 1
'For Each Entite In Selection_Symbole
'Next Entite
Set Block = Selection_Symbole(0)
Select Case Block.Rotation
'Virification de l'orientation de l'anglulaire de la ligne
'¦ Correspondance des angles dans AutoCad ¦
'¦--Degrès--¦---GetAngle Returns-¦-GetOrientation returns--¦
'¦ 0 ¦ 0.0 ¦ 1.5707963267949 ¦
'¦ 90 ¦ 1.5707963267949 ¦ 3.14159265358979 ¦
'¦ 180 ¦ 3.14159265358979 ¦ 4.71238898038469 ¦
'¦ 270 ¦ 4.71238898038469 ¦ 0.0 ¦
Case 0
Coordonnees_Ligne_1(0) = Block.InsertionPoint(0) - 4
Coordonnees_Ligne_1(1) = Block.InsertionPoint(1)
Coordonnees_Ligne_1(2) = Block.InsertionPoint(2)
Coordonnees_Ligne_2(0) = Block.InsertionPoint(0) + 4
Coordonnees_Ligne_2(1) = Block.InsertionPoint(1)
Coordonnees_Ligne_2(2) = Block.InsertionPoint(2)
Case 1.5707963267949
Coordonnees_Ligne_1(1) = Block.InsertionPoint(1) - 4
Coordonnees_Ligne_2(1) = Block.InsertionPoint(1) + 4
End Select
Block.Delete
'Creation du jeu de selection
Set Selection_Ligne1 = ThisDrawing.SelectionSets.Item("ss1")
Selection_Ligne1.Delete
'Selection de la première ligne
Set Selection_Ligne1 = ThisDrawing.SelectionSets.Add("ss1")
Selection_Ligne1.SelectAtPoint Coordonnees_Ligne_1
'Selection de la deuxième ligne
Set Selection_Ligne2 = ThisDrawing.SelectionSets.Item("ss1")
Selection_Ligne1.SelectAtPoint Coordonnees_Ligne_2
Set L1 = Selection_Ligne1(0)
Set L2 = Selection_Ligne1(1)
'Test pour supprimmer les ligne = OK
'L1.Delete
'L2.Delete
'Joindre les deux ligne
ThisDrawing.SendCommand "_join" & vbCr & L1 & "," & L2
End Sub
Thanks in advance for your help! 😉
En vous remerciant par avance pour votre aide! 😉
