Run macro when move objects
seabrahenrique
seabrahenrique
Hello guys…
It’s possible to run a macro automatically when a move some object in my model space? After move a block for example….
In VBA for excel I have this option… codes “running by events”….
Can we make something like that in VBA for AutoCAD?
Thanks in advance 🙂
MakCADD
you can use event handler in vba
which let you run a macro when an event takes place in the document
select object AcadDocument from the dropdown list,
then you can see the available built in events in vba
seabrahenrique
Thanks @MakCADD!
I made a solution with your proposal and a lite bit more of codes... The final results is here:
Private Sub AcadDocument_EndCommand(ByVal CommandName As String)
 If CommandName = "MOVE" Or CommandName = "GRIP_STRETCH" Or CommandName =
 "DROPGEOM" Then
   'CODE EXECUTION HERE
End Sub
