Insertionpoint through handle
nucliabrasil
nucliabrasil
Hello guys!
How do I get the x and y coordinates of an "AcDbBlockReference" from its handle with vb6.
Thankful.
norman.yuan
If you know an AcadEntity's handle, you can call AcadDocument.HandleToObject() to get an AcadObject. Something like:
Private Function GetInsertionPointByHandle(handleVal As string) As Variant
    Dim obj As AcadObject
    Dim blk As AcadBlockReference
    Dim pt As Variant
    '' If your code is BV6, not VBA in AutoCAD, you need to
    '' obtain your own "ThisDrawing" object
    Set obj = ThisDrawing.HandleToObject(handleVal)
    If TypeOf obj Is AcadBlockReference Then
        Set blk = obj
        pt=blk.InsertionPoint
    End If
    GetInsertionPointByHandle = pt
End Function
Norman Yuan
Drive CAD With Code
nucliabrasil
Thanks Noman Yuan!
