insert points ID with coordinates from excel to autocad using vba
ahmed.ongame
ahmed.ongame
hi
i want a VBA code that inserts a block in autocad by the coordinates i have from excel and the block should show me the(x , y , z) and point ID of the point block so when i see the point i know which point is which.
if someone can help it will be very helpfull to me and thanks.
Ed__Jobe
To get you started, here is a block in this thread that someone posted. How much experience with vba do you have?
Ed
How to post your code.
ahmed.ongame
not that much
just some basics i have received from my course in college
i realy want to solve it
i have a file that do this job except the ID part, it is just importing the coordinates
Ed__Jobe
This thread shows how to get the xl cell's content.
Use the xl data to build a 3D point object and then use the ThisDrawing.ModelSpace.InsertBlock() method to insert the block. The example in Help shows you how to build a 3 element array of doubles for the point and how to use the InsertBlock method.
Ed
ahmed.ongame
what i really need is just the insert block method and attrabute with it
Ed__Jobe
Just be sure to set an object using the insert method. e.g. Here's some quick code.
Dim oIns As AcadBlockReference
Dim oAtts As Variant
Dim i As Integer
oIns = ThisDrawing.Modelspace.InsertBlock 'add args
oAtts =  oIns.GetAttributes
For i =LBound(oAtts) To UBound(oAtts)
   If oAtts(i).TagString = "SomeName" Then
      oAtts(i).TextString = "txtFromXl"
Next oAtt
Ed
